C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
What do I need?
Old Mar 2, 2008 | 08:40 PM
xkilo16x's Avatar
xkilo16x
Default What do I need?
Hey guys,
I'm new to the entire nitrous and/or forced induction concept. However, I'm tired of throwing on a couple bolt ons and getting minor performance. So I'm interested in putting in a 150 shot of nitrous. Now my question is, since I don't know much about it and I'm probably going to have Cartek do the install, what components will I need to run a nitrous set up? I don't want bare minimum, but I want something that will safely allow me to handle a couple sprays per week.
My supporting mods are the Vararam, Bullets Exhaust, Tune, and 160stat. I plan on getting my manifold ported and Kooks headers before I put in the spray though.
Thanks,
Dan
Old Mar 3, 2008 | 08:19 PM
SoldSyclone's Avatar
SoldSyclone
Wet Nitrous Outlet Plate Kit.
Best ET / MPH so far 125 shot: 11.1 / 125 at 2800 feet
This is by no means the least expensive kit but I like the 6 fuel and 6 N20 ports for there atomization or better distribution of fuel and N20 IMO.
650 Base Nitrous Outlet 90mm Plate kit
129 Window / WOT via tps switch
I also run 100 unleaded every time I spray, I run the tank 20 miles past the low fuel warning and add 5+ gallons of 100 octane unleaded.
IMO one should get a N20 tune and verify AFR at the very least.
I use HP tuners and a Inovative WB to monitor my AFR and Knock Retard.
Plate installed just like a TB spacer (Black lines are HSW).
Close up of the plate (they come black but this pic shows the ports well).
Plate kit http://www.nitrousoutlet.com/catalog...del=37&dept=11
Window / WOT Switch http://www.nitrousoutlet.com/catalog...del=86&dept=11
Dave, Chis and Ray from Nitrous Outlet have been great.
http://www.nitrousoutlet.com/index.asp
Lots of good N20 info at LS1-LS2-LS6-LS7 PERFORMANCE Nitrous Oxide section
http://www.ls1tech.com/forums/forumd...aysprune=&f=10
Old Mar 3, 2008 | 08:37 PM
xkilo16x's Avatar
xkilo16x
WOW, thank you very much for the information. It was very helpful. I know exactly what I need now.
To What do I need?
