C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boost ?
Old Mar 7, 2008 | 09:49 PM
chxwing's Avatar
chxwing
Default Boost ?
Could you please tell me at what rpm do you see maximun boost and what driving conditions do you see it. (hard pull, etc.)
David
Old Mar 7, 2008 | 09:58 PM
chxwing's Avatar
chxwing
I know this kind of a stupid question.
Old Mar 7, 2008 | 10:15 PM
o0 zeno 0o's Avatar
o0 zeno 0o
David
Depends on what system your talking about...
In a positive displacement system (like the maggie), it's once your in boost all the way up (though the heat from compressing the air causes the system to "run out of air" so to speak). So if your running 7psi, you run 7psi throughout mass of the positive boost range.
On a centrifugal charger (like the procharger or paxton), boost increases with the RPM's at a rate of x^2. So if your running 8psi at 6000rpm, your running around 4psi at 3000rpm. In this case, you get max boost at your max rpm.
Old Mar 7, 2008 | 10:20 PM
chxwing's Avatar
chxwing
But do you have to be under a load, just reving the engine will not produce boost right? I am talking about the paxton.
Old Mar 7, 2008 | 10:23 PM
o0 zeno 0o's Avatar
o0 zeno 0o
I don't think it's a stupid question at all... Knowing what your getting out of your system lets you know how to better use that system to attain your goals.
Do keep in mind that the basic boost math is only half of it. The centrifugals tend to get higher numbers in the max rpm range, where as positive displacement blowers give great low end and start to run out of air up high do to heat/density gains and a loss of entropy change.
Edit: err.. that's heat gains resulting in density losses.. My bad, drinking beer ;0p
Old Mar 7, 2008 | 10:30 PM
o0 zeno 0o's Avatar
o0 zeno 0o
Well, it's run off the crank so I would assume that if the RPM's go up, the SC will spin. So if you drop the clutch at 3000rpm I would think you're gonna have that 3psi there. I'm not really positive on practice though, so I would ask that question to one of the tuners.
I was a ME major, so I know the concept part of it... But as one of my old professor's use to say, there's nothing more dangerous than an Engineer with a toolbox.
Edit: ME == Mechanical Engineering, btw... Technically "Compressed Flow" is Aerospace Engineering material, so weigh it as you see fit.
Old Mar 8, 2008 | 12:21 AM
Skunkworks's Avatar
Skunkworks
Although this will go down hill quick... revving your engine with no or little load should not get you much boost with centri do to bypass valve!
The purpose of the bypass valve is to protect compressor (ATI, Paxton, Votech...) or keep it from surging. That meaning because compressor is mechanically coupled it will produce X mass flow and depending on restriction X boost (oversimplified). So if you rev engine to 6000 RPM downshifting for corner, you do not need extra mass flow supercharger is producing...
A bypass valve simply vents excess flow (resulting in boost do to restriction) until vacuum is lost (high throttle opening). Or most simply put until you put your right foot into it.
It is somewhat normal to gently rev engine and not see boost with centri. The bypass valve is simply doing its job.
Oh, "o0 zeno 0o" it's not a squared but it is exponential when describing boost of centrifugal.
Mike
Old Mar 8, 2008 | 12:25 AM
Skunkworks's Avatar
Skunkworks
I always thought it was "mass flow"... if your talking true engineering and not automotive FI.
Mike
Old Mar 8, 2008 | 12:58 AM
o0 zeno 0o's Avatar
o0 zeno 0o
Mike
Hrmmm.. I thought a centrifugal increased at the square of it's speed, which would be x^2, not n^x... I could be wrong though, it's been a while.
Old Mar 8, 2008 | 01:05 AM
o0 zeno 0o's Avatar
o0 zeno 0o
Mike
Well, there is a huge difference between fluid dynamics, which is a relatively non-compressible flow (meaning the compression is negligible, not non-existent) and compressed flow (seen in propulsion).. But yup, in fluids we call it mass flow.
Old Mar 8, 2008 | 10:34 AM
wewing's Avatar
wewing
Simple answer for me, at WOT, my boost climbs to 160kpa by 3500 rpm and my boost controller has it stay there until red line. I have the APS twin turbo kit, and a manual boost controller. No hard math. Since they're turbos though, I have actually hit max boost by 3000 rpm before when upshifting, and if it isn't a WOT run, it may never hit max boost.
To Boost ?
