C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Warning: Please Read
Old Apr 11, 2008 | 06:09 AM
EC_Tune's Avatar
EC_Tune
Originally Posted by thrasher949
Too much fuel in the exhaust....this will cause the cats to get too hot which makes them melt....therefore causing them not to allow air to pass through them. The answer is in the tune my friend. There are plenty of oem cars with FI that have cats in the manifold (ie Mini Cooper type S).
Or if you previously had a cam that had a huge overlap I could see that doing the same thing (basically dumping raw fuel into the exhaust)
Just in case you didn't know this:
OEM level Cat Over Temp protection systems enrich the fuel ratio to cool the cats and then they actually add timing (up to 10 degrees in some applications) with the significantly enriched mixture. You can see it in every OEM calibration. GM trucks have a rather aggressive COT protection - Max commanded AFR could be 8.02 with maximum COT protection active at 4800 RPM on a 2006 5.3L!!!
I also had the pleasure of knowing John Germanson over at Magnuson and had the opportunity to discuss COT with him as he was testing internal cat temps on Magnuson's engine dyno. How does 800+ ft/lbs on a 6L motor running for an hour at 4000 RPM's and not overheating the OEM cats sound? He was measuring the internal brick temp as well as the inlet and outlet temperatures of the OEM cats. It's all about the fueling and timing for cat thermal protection.
If you want to kill the cat quickly, run it lean with low timing.
Old Apr 11, 2008 | 08:50 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
As far as the offroad pipe goes its only 450.00$ It bolts on and off
Do as you like, Its not worth it to me to take a chance and blow a head gasket or worse. 450 is insurance that I wont have a problem and help with some horses with the paxton and 8 pounds of boost
Old Apr 11, 2008 | 09:09 PM
o0 zeno 0o's Avatar
o0 zeno 0o
And then we all get to smell you going down the street.. The performance hi-flow cars are the way to go. Good flow, no smell, less emissions.. Everyone's happy.
Old Apr 11, 2008 | 09:28 PM
dstage's Avatar
dstage
Originally Posted by 06.Z51.MontRed.Vert
Shane do you think us guys using high flow cats from LG or other header manufacturers are ok?
Glad to hear the damage wasnt too extensive for you.
I got the LG high flow cats running 11 psi on a STS kit for about 20,000 miles and no problems.
Old Apr 11, 2008 | 09:52 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
It doesnt smell bad Im not taking any chances
Old Apr 11, 2008 | 11:18 PM
huckleberrydude's Avatar
huckleberrydude
Chevy should just go electric
No problem with cats at all, just don't want to tear down again or have a breakdown. My car smells nice
Old Apr 12, 2008 | 12:29 AM
DSOMC6's Avatar
DSOMC6
$450??? The offroad pipes are two round pieces of stainless about 12" long. That's it.
Old Apr 12, 2008 | 03:31 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
You could do those 12 pipes too. The offroad pipe is longer 3 feet or so
I just left Chris at ECS a couple of hours ago He says unless your running 14 psi of boost or more you dont need the offroad pipe.
I plan to run 8psi so he said no exaust is needed. He says the paxton D1 sc 600 on a stock vette no other changes except slicks will run in the 10s!!!!!
I said what???????????? he said it again. He also said not many people can drive that well or launch the car. Chris also said the clutch wont last long doings this. He said the car wasnt designed to race on 1/4 mile strip. Atco raceway in NJ wont let you run that fast without a roll cage etc anyway so street racing it is.The reason guys are blowing head gaskets, melting cats etc is a bad tune. When I saw Chris he said the same thing those cars with the cat and head problems
need a tune. Boy did I learn alot today
Old Apr 12, 2008 | 04:18 PM
o0 zeno 0o's Avatar
o0 zeno 0o
If anybody would know, those guys would. Thanks for sharing the info
Old Apr 12, 2008 | 06:32 PM
06.Z51.MontRed.Vert's Avatar
06.Z51.MontRed.Vert
From: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
St. Jude Donor '08-'09
I agree!
