Not sure how long it will last but i can tell you after adding a blower all this car does is bang off the rev limiter. Not fun and very anoying. Cars days are numbered. Was told when it senses spin even if the rev limiter is raised it will do it. IM NOT HAPPY !
You need to have the rev limiter raised by 200 rpms and the shift mph lowered 2-3 mph......this gives the transmission more time to complete the shift. I had the same problem, this solved it.
I know of 3 A6s that have come apart at 550-600 rwhp.
Thanks dude. Its really getting on my nerves. It even did it the other night on the 4 to 5 shift when i was racing a modded shelby 500 and i know the tires were not spinning. Im just glad i won...LOL !
wow, do you know how long they were running the tranny w/ that power? were they tuned properly or revving like this guy?
All were tuned properly and came apart within 6 months. I know of 2 around the 700 rwhp level that are still running fine after 6-12 months but they are both centrifugal cars. I think a centrifugal supercharger (without all of the low end torque) places less strain on the trans then a roots blower or twin turbo.
550 rwhp and above is a gamble IMHO............
if you are in paddle mode does the auto trans downshift on its own when you are cruising in 3rd or 4th and hit the gas?
No, paddles you controll the shifts yourself. If you mash the pedal in third with the paddles on, it will stay in third untill you hit the upshift button.
once the shift pressure problem is dealt with, all the current trans builders will be able to pile against the 6L80 like there's no tomorrow; look for built transmissions to support well in excess of what the built 4L85's can handle
and besides, a 6L80 shares more than half of its components with a 6L90, which is rated for 664 ft lbs (compared against the 4L80E's 440; 4L85 is 460)
_
you are a messenger from God... if you see him/her again.. thank em for my vette... and forced induction... lol
the 6L series and the 6T series transmissions from GM actually has a direct clutch to clutch interface, and the trans is actually able to meter the amount of fluid going out of every shift
which means if it sees more or less fluid than what is "normal" or OE stock, it goes to limp mode
which is why no trans company as of yet has released a built 6L80 or any 6L or 6T series trans yet
also have you considered an upgraded torque tube shaft?
the OE aluminum one does hold up well to increased power either
try for a carbon one or a HD ALU setup; no one as of yet makes a carbon shaft for the A6 (and i've been looking around for a LONG time - if you know someone please let me know IMMEDIATELY), and the HD aluminum shaft requires some welding
not pleasant either way
_
you know more about it than me.. add me and keep me in the loop! my AIM is in my profile if you want to ever talk shop!!... that goes for the rest of the people on this forum... feel free to AIM me whenever!
