C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boost a Pump setting
Old May 10, 2008 | 05:24 AM
C6 Twin Turbo's Avatar
C6 Twin Turbo
Default Boost a Pump setting
I have an asp tt car. I am wanting to make sure of the msd boost a pump voltage setting. Is the setting to be 15 -15.5 under boost?
Thanks for any help
Old May 10, 2008 | 06:30 AM
wewing's Avatar
wewing
It depends on your car's tune. I believe the tune from APS calls for that, so if you're using that one, then yes, but otherwise it needs to be set to whatever your tuner set it to when he tuned the car.
I have my Kennebell boost a pump on my APS car set to max voltage under boost, or around 17.5 volts because that is what I chose to set it to when I tuned it.
Old May 10, 2008 | 07:23 AM
aTX427
Guest
Posts: n/a
mine is on max voltage, then they tune for the extra fuel.
Old May 10, 2008 | 08:13 AM
99 C-5 F1C VETTE's Avatar
99 C-5 F1C VETTE
Old May 13, 2008 | 05:06 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I thought setting the MSD to max output was undesireable because it could be ~20V.
I'd recommend using an air compressor to hold the pressure to the MSD at your max boost and then read the fuel pump leads with a voltmeter. Adjust accordingly.
Old May 27, 2008 | 11:22 PM
GETUSUMM's Avatar
GETUSUMM
Would you happen to have or know where I can get detailed instructions for installing one in a C6? Mine will be here in the morning. Thanks
Old May 27, 2008 | 11:56 PM
MARSC6's Avatar
MARSC6
I got the racetronix harness to make it all plug and play.
http://www.racetronix.com/RX-C5A-FPWH-2.html
To Boost a Pump setting
