C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E85 instead of Methanol
Old Jun 20, 2008 | 01:30 PM
fright88's Avatar
fright88
Default E85 instead of Methanol
Ok so I went with a friend last week to get some work done on his STi while waiting we talked to the shop guys and they asked about my car. I told them I had a Paxton from ECS and that I was thinking about adding Methanol. Their opinion is I should just switch to E85 as they feel that there is less to go wrong on E85 and it is fairly readily available now.
I was just wondering what everyone's take is. Why more people don't go E85 instead of meth.
Thanks for any advice.
Old Jun 20, 2008 | 01:43 PM
Earl H's Avatar
Earl H
What can go wrong with meth vs. 85? The injection system can fail on either fuel supplement. Straight meth will likely yield a cooler chart and better octane boost, at equivalent flow.
RE: using 85 as a primary fuel...I have/still contemplating going that route as E85 has a higher octane than Sunoco 94 and burns cooler. I've heard that cold starts can be an issue, but I don't drive my car in the winter time anyway.
Old Jun 20, 2008 | 01:55 PM
fright88's Avatar
fright88
Yeah their position is that you don't have an extra pump or wiring. They also claimed cooler temps with E85.
Old Jun 20, 2008 | 02:05 PM
Earl H's Avatar
Earl H
So you are saying no meth injection and running on straight E85?
Old Jun 20, 2008 | 02:46 PM
fright88's Avatar
fright88
That is what they were suggesting yes.
Old Jun 20, 2008 | 03:08 PM
Earl H's Avatar
Earl H
Dowside, you will need E85 compatible hardware (lines, fittings, pump, injectors, etc.)...larger fuel pump (or at least 30-50% more flow capacity at desored hp level) and larger injectors (ditto). Personally, I am interested in making the switch (just gotta convince Dr. Phil). If I were keeping th Viper, I would switch to E85 as I have the lines, rails, pump, etc....just need larger injectors. There are likely others. This is based on my limited research.
Upside: Higher octane, cooler burn. Can ditch the Meth setup as it isn't really need as much.
Old Jun 20, 2008 | 05:05 PM
Virt's Avatar
Virt
I've been hearing that E85 gets your worse mileage than unleaded, is that true?
Old Jun 20, 2008 | 05:22 PM
fright88's Avatar
fright88
Yes this is true. I talked to a couple STi guys who had E85 tunes. They gained about 10% but lost about 25% mpg however it is about 25% cheaper around here. So if cost is the issue it seems to almost even out. If distance is the issue the you lose about 25% distance.
However upgrading the pump fuel lines and injectors again sounds like to much of a pain. Meth here I come
Old Jun 20, 2008 | 06:00 PM
Mr.Big's Avatar
Mr.Big
I just built a custom fuel system for E85, I will be running E85 and Methanol Injection together, install was just finished last month... We still have a few more things to do to the car before I make the switch, but that's the plan...
Old Jun 23, 2008 | 03:07 AM
aTX427
Guest
Posts: n/a
My understanding is e85 does not have the corrosive properties of methanol, thus not requiring any changes to the fuel system other than what you mentiond in the way of additional fuel capacities from the pump, maybe the line size and injector.
Old Jun 23, 2008 | 03:09 AM
aTX427
Guest
Posts: n/a
Curious, why you are running meth injection with the e85? Is your guy in Dallas able to tune e85 and is it regularly available out there? We have maybe three pumps in Austin. I really want to go that route as well, but would have to get a truck bed tank and fill the car at my house before I head out for the day.
Old Jun 23, 2008 | 06:23 AM
Earl H's Avatar
Earl H
I would look into it a bit more.
Old Jun 23, 2008 | 10:09 AM
No Juice's Avatar
No Juice
You are correct. Regular gas is 10% ethanol already so your lines, fittings, pump, tank, and injectors can handle it. You will need the added supply.
Earl, have you done some testing to prove this wrong? if so please share.
Old Jun 23, 2008 | 11:25 AM
aTX427
Guest
Posts: n/a
there has been considerable discussion on the topic. Of course time will tell if the claims are true.
http://www.ls1tech.com/forums/showthread.php?t=602091
Old Jun 23, 2008 | 12:09 PM
Earl H's Avatar
Earl H
OEM's E85 vehicles spec different fuel system components for a reason. E85 is more corrosive than regular gasoline, despite what this link says. Everybody has to make their own choices. My research says certain changes or compatability issues must be addressed.
Hot Rodders/Tuners don't have to do the rigorous testing that OEM have to. Their setups only have to work as its leaving the shop.
Old Jun 23, 2008 | 01:07 PM
Busa196's Avatar
Busa196
I'll stick with meth as E85 is almost nil around here.....and Meth is cheap, my car burns very little of it and if I ever “run-out” and don’t have time to go to the mod shop to buy some, I simply walk into my local home Depot and buy some Denatured Alcohol. I’d never switch based on the “convenience” factor alone.
Old Jun 23, 2008 | 05:02 PM
Mr.Big's Avatar
Mr.Big
John,
For the pure cooling efficiency and added octane (as for both)...
Yes, Taylor can and does tune for E85.
E85 is offered at the "Kroger" grocery store stations, here in Dallas (there are several)...
I have the setup designed so I can switch maps on the fly...So If I travel in the car where no E85 is available, I just throw the other tune in the car and 60 seconds later I can change fuels... Yes this is all for performance only... But that's our hobby... It's a LOT easier than it sounds... Promise...
To E85 instead of Methanol
Old Jun 23, 2008 | 07:16 PM
o0 zeno 0o's Avatar
o0 zeno 0o
Can't wait to see the results of the setup! I thought about it myself, but the higher fuel requirement and the high price of E85 around here have kept me away...
Don't know how it is around there, but here E85 prices adjust themselves with gasoline. What a sham.
Old Jun 23, 2008 | 08:09 PM
aTX427
Guest
Posts: n/a
John,
Are you running an aftermarket ecu to be able to swith on the fly? I really want to go down the e85 path - BAD! I had Naty @ Nasty Per quote me on his stage 3 street kit with dual W340 intake pumps, Fuel Labs regulator, hard anodized fitting, hose ends and methanol quality hose, just in case they install more stations around here. All I would need to do is get a low impedance converter and larger injectors.
Old Jun 23, 2008 | 09:24 PM
Earl H's Avatar
Earl H
... hard anodized fitting, hose ends and methanol quality hose, just in case they install more stations around here. ...
...thought the thread you referred said that no special meth compatible hardware was needed?
