ok the boost a pump is running about 100 kiles and then it melted and popped a fuse. checked everything and it was fine. so replaced fuse and went on....then it did it agian but this time it melted the fuse holder completly!!! any body else had problems like this. any ideas what the issue is. i going to call msd in the morning to see what they say
Do you have any type of fuel pressure gauge installed? I don't have any experiences with boost a pump but a lot of time when it blows a fuse is when the pump is binding.
itran for 100 miles then popped ( fuse melted bad!!!) then changed it. ran for over 100 miles agian ad this time total melt down of holder ect. so what do you do to fix yours. i ws looking at sapping to metal car audio fuse holder but afraid it just move the problem down line to the wireand melt them.....
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I have seen that before, the causes were 1. there were two pumps being fed by the BAP-stock and an extra in line pump. Current draw was too high but didn't not pop fuse right away, just melted it down. 2. was from a loose connection in the fuse holder, we removed the fuse holder provided and installed a more HD piece. Problem was solved after removing the second pump on the first one, and the new fuse holder on the second.
I have read about wires melting with running off the stock setup, I know several guys on the c5 FI forum are runing the racetronic hard wire setup for their BAP, only $75 and great insurance.
