C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Fuel Pump Done
Old Jul 22, 2008 | 08:58 PM
vetteboy2k5's Avatar
vetteboy2k5
Default Fuel Pump Done
Just like it says, my fuel pump went and I am looking to replace. I have sts twin turbos and a msg boost a pump. I just wanted to know about any good after market replacements out there, or if the zo6 fuel pump would work?
PS- New to phoenix and was wondering if anyone knew a shop that is pretty good.
Old Jul 27, 2008 | 07:36 PM
gengiskhan's Avatar
gengiskhan
good question
im wondering what set up the zr1 will use and can we in normal c6's use it
Old Jul 27, 2008 | 08:54 PM
aTX427
Guest
Posts: n/a
Nasty Performance makes a nice P-n-P twin in tank that uses a Racetronix harness.
Old Jul 28, 2008 | 07:57 PM
vetteboy2k5
Well, I met with the guys over at Xtrememotorsports and they will be replacing the fuel pump with a stock Z06 one. They said its been done to many forced induction C6's without problem. Has anyone else had experience with the Z06 pump in the stock C6?
Also, how long is the average time to install a fuel pump?
Old Jul 29, 2008 | 12:33 PM
AVETTE's Avatar
AVETTE
Cruise-In II Veteran
Cruise-In III Veteran
Default my fuel pump is gone now too!! 07 aps tt with msd boost a pump
This seems like a serious problem now. I have only 7k miles on the car and first a relay went and dealer charged me 300 bucks plus 100 for a tow. Now they say fuel pump is gone got stranded on the highway, almost got hit by a semi, now they want 1000 in labor say they have to drop fuel tanks and 200 for fuel pump and tech says it will probably just happen again APS where the heck are you?????????????????????
THIS IS BS
Old Jul 29, 2008 | 01:57 PM
07MontRedcp's Avatar
07MontRedcp
THIS IS BS
There seems to be a tendency for the MDC boost a pump to not maintain the voltage setting. When LAPD did my APS install, they trash canned the supplied MDC unit and instead went with a Magna-Volt.
To Fuel Pump Done
