C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
M112 or M122?
Old Aug 20, 2021 | 01:26 PM
  #61
schpenxel's Avatar
schpenxel
St. Jude Donor '15
This might be what you're going for:
http://www.paulsautoand4x4.com/pauls...%20Systems.pdf
Old Aug 20, 2021 | 02:18 PM
  #62
_zebra's Avatar
_zebra
either way, i prefer my TVS unit over either MP. the efficiency & power potential is way better.
as for LS1 vs LS2 asked a dozen years ago: the kits had different hardware & components between the C5 & C6 installations (pumps, tanks, lines, etc). i know because they initially sent me a C6 kit for my FRC, and they didn't fit.
Old Aug 20, 2021 | 02:27 PM
  #63
TXSTICK's Avatar
TXSTICK
Yea, this is a 13 year old thread that was brought back from the dead (not by me).
Back then I had an LS2 and I was looking for a solution, now I have an LS3 with the Heartbeat and it works for what I need.
Old Aug 20, 2021 | 02:59 PM
  #64
_zebra's Avatar
_zebra
yeah, the heartbeats were good so long as you didn't try to spin them fast.
Old Sep 22, 2024 | 12:58 PM
  #65
Vin.da.goat's Avatar
Vin.da.goat
1st Gear
Originally Posted by old motorhead
Go with the 122. Torque will be there either way. I have a GMC truck with 6.0L LQ4 that started with a 112 and wound up with a 122. The truck has 220/580/115lsa cam along with long tube headers and open exhaust. The LQ4 is a lower compression version of the LS2 with a milder cam. I believe the heads are the same or similar.
With the 112, it made 440 rwhp on a very stingy dyno. Same setup with the 122 made 480. Doesn't sound like much of a difference, but it's night and day difference. There's no loss of low end grunt. Your LS2, with an extra point or two of compression, ought to be stout.
If you were going to leave the engine as is without ever adding any mods, the 112 would be a nice bump in power. However, the extra .8K would be well spent if you ever want to go higher (and you will).
I'm curious as to what adapters or intake manifold u used
Old Sep 22, 2024 | 06:40 PM
  #66
old motorhead's Avatar
old motorhead
Wow, that's a blast from the past. The blower takes the place of the intake manifold. As far as I know, the 112 and 122 would only bolt up to LS engines with catty port heads.
Old Sep 24, 2024 | 02:04 AM
  #67
_zebra's Avatar
_zebra
checks to the best of my knowledge.
by the time the rectangle port (LS3+) heads came out, they'd stopped making MP kits & transitioned to all the TVS-based variants. i'm aware of three different manifold designs / shapes: one for cathedral port heads (used on MP & TVS), one for rectangle port heads (TVS), and one specifically noted for the LS7 & 2650 kits (not sure why the shape changed, but it did).
