C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
tps wire? HELP!!!!!!!!!!!!!!!!!
Old Sep 22, 2008 | 03:23 PM
Z06JOEL's Avatar
Z06JOEL
Default tps wire? HELP!!!!!!!!!!!!!!!!!
I have an 08 ls3 I'm hooking up a nitrous system I need to know which wire on throtle body sends tps signal
Old Sep 22, 2008 | 03:49 PM
jogar80's Avatar
jogar80
Dunno on LS3 but on the LS2 it was the purple wire on the throttle body harness.
Old Sep 23, 2008 | 06:49 AM
Z06JOEL's Avatar
Z06JOEL
not the purple one thanks for your response
Old Sep 23, 2008 | 06:51 AM
Z06JOEL's Avatar
Z06JOEL
HELP GUYS!!!!!!!!!!! Please my whole system is done except for this cable
Old Sep 23, 2008 | 11:20 AM
EdwardETraylorIII's Avatar
EdwardETraylorIII
Joel,
I really believe it's the purple one. That's consistent across most new GM vehicles.
Are you absolutely certain this isn't it? It's relative easy to check. Just connect a volt meter across it (and ground the other side), turn the ignition on, and give it gas. The voltage should increase. You might have to have a buddy watch the meter (or give it gas). It's easier with two peeps.
Old Sep 23, 2008 | 12:26 PM
Z06JOEL's Avatar
Z06JOEL
Originally Posted by EdwardETraylorIII
Joel,
I tried this did not see change in voltage
Old Sep 23, 2008 | 02:22 PM
GenuineSurprize's Avatar
GenuineSurprize
just use put a switch under the pedal and call it a day. i had ur same problem 3 months ago. installed the entire kit and couldnt find the right cable so i said **** it and connected it to a switch under the gas pedal. love it that way, no problems
Old Sep 23, 2008 | 08:03 PM
SoldSyclone's Avatar
SoldSyclone
Which Window/WOT switch are you using?
If its Nitrous Outlets call them they are always great
I also thought it was purple rising voltage did you search it?
Look under my name for a few posts
Old Sep 23, 2008 | 09:05 PM
EdwardETraylorIII
Are you certain you have a good ground when you checked it?
The harness is almost identical (on the motor side) on your car and mine.
I always use NX kits - however, this shouldn't have any impact on the proper selection of TPS sensor wire.
Old Sep 24, 2008 | 05:11 PM
Z06JOEL's Avatar
Z06JOEL
My friend gave me the switch I really don't know who makes it
Old Sep 24, 2008 | 05:12 PM
Z06JOEL's Avatar
Z06JOEL
I used the the battery
Old Sep 24, 2008 | 05:18 PM
patton's Avatar
patton
St. Jude Donor '09
for whats its worth,its easier imo to use a micro switch.that way there is no issues with TM pulling throttle [you do have TM adjusted]
Old Sep 24, 2008 | 07:07 PM
GenuineSurprize
yeah just got with a micro switch, u cant go wrong.
Old Sep 25, 2008 | 06:39 AM
Z06JOEL's Avatar
Z06JOEL
yes
Old Oct 4, 2008 | 01:51 PM
Z06JOEL's Avatar
Z06JOEL
MICRO SWITCH IN
To tps wire? HELP!!!!!!!!!!!!!!!!!
