C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
check engine light
Old Oct 19, 2008 | 06:34 AM
R50THC5's Avatar
R50THC5
Default check engine light
Had this come on after a WOT burst. Tuner suspect boost pump may have stopped working. My fuel pressure still read 62lbs. It came on again this morning coming home from work at lass than 30mph. ?? Before I drive 200 miles to the tuners shop in Indiana, has anyone experienced this and was it related to the S/C install or some other item on the car. Any feed back great appreciated. I was planning on going to the tuner
Monday morning.
Old Oct 19, 2008 | 11:26 AM
Mr.Big's Avatar
Mr.Big
we need more info to help you... what code is the scanner showing. If you do not have a scanner, go to Walmart and pick up a $30 obdII scanner, and let us know the codes that it reads, also we need to know what year model car you have, and what mods are done to it... Was the car tuned on the dyno, or is it just running on the canned tune? help us help you with this info...
Old Oct 19, 2008 | 12:09 PM
R50THC5's Avatar
R50THC5
Sorry...06A6 cpe it coded 0171 0174. I have an EFI live tune p-1 procharger and dynoed 471rwhp on a mustang dyno Aug 2007 when installed.
Old Oct 19, 2008 | 12:18 PM
patton's Avatar
patton
St. Jude Donor '09
from helms manuals 07 0171 fuel trim system lean bank 1 /0174 is alike but for bank 2 . do the basics check for vac. leak
Old Oct 19, 2008 | 12:28 PM
R50THC5's Avatar
R50THC5
Thanks, that concurs with the codes on my hand held. I will have that checked when I take it to the tuner Monday. Tuner thinks maybe the boost-a-pump may have quit, but the pres gauge read a consistant 62psi but I have 60lb injectors also. Should have paid more attention in shop but that was 40+ years ago. Thanks again
To check engine light
