C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Bog during boost?
Old Dec 8, 2008 | 12:21 PM
csun213's Avatar
csun213
Default Bog during boost?
Hi guys, need a little help.
I have a Vortech supercharger on a C6 with LG headers and running about 6psi boost with a 4.5 in pulley so the car is pretty safe putting down about 500rwhp.
The problem I am noticing sometimes is when I am in 2nd or 3 gear (A6) and into boost, the car will pull hard for a while and then all of a sudden, it will bog.
It used to happen once in a while but now it is happening more often.
Can someone tell me what to look for? At first I thought I was over rev the engine and hit the rev limiter but I noticed I was only at 5800-6000rpm when it happened last time.
It also happens a lot when I get into boost but then back off. Is this normal to bog when I back off while in boost?
I am going to get my tuner to look at his tune (HP) but he is under the weather right now.
Thanks for any help.
Old Dec 8, 2008 | 12:43 PM
jonjon's Avatar
jonjon
Are you running meth?
Old Dec 8, 2008 | 12:49 PM
csun213's Avatar
csun213
No, I was told since I am only running about 6 psi, I would not need it.
Also it does not happen all the time, just once in a while however it is happening more and more often now.
Old Dec 8, 2008 | 04:09 PM
rwebcon's Avatar
rwebcon
Default I have the same.
I have the same thing happening. To the best of my knowledge it’s occurring because of wheel spin and TC. The control module is pulling timing and reducing power to the wheels, it thinks you’re out of control. I submitted the same question a while back and this explanation is the best I could get. I have not tried it but go to comp mode and see if it helps. Then try turning everything off and see what you get. Of course do it in a safe environment it my get a little difficult to handle. I would try this before I go back to the tuner. Let me know what you fine.
Old Dec 8, 2008 | 05:27 PM
EdwardETraylorIII's Avatar
EdwardETraylorIII
Charlie,
Hey man! Remember me?
Sounds like you might need to change your plugs - especially if you've run any leaded fuel.
Do you have an A:F gauge? If so, what's the number when you experience this? Any DTC's?
It could be torque management but I'm inclined to believe it's something else since you seem to think it's happening more often as of late.
Old Dec 8, 2008 | 06:06 PM
csun213's Avatar
csun213
Originally Posted by EdwardETraylorIII
Charlie,
Yes, I do remember you. Nice to hear from you again.
I have never run anything but unleaded 91/
Don't have an A/F guage since I wouldn't know how to read it.
Nothing on the Display.
It is happening more maybe because of the colder weather? It has happened a few times on Thunderhill road course.
Old Dec 8, 2008 | 06:09 PM
csun213's Avatar
csun213
I don't think it is wheel spin because most of the time I am moving about 50mph and down shifted to 2nd or 3rd to get into higher rpm.
It would be in boost and running great until I lift a little to slow down and it will bog big time (where I am thrown forward).
Old Dec 8, 2008 | 06:11 PM
EdwardETraylorIII
Charlie,
Do you turn traction control off when you first start your car each time you get in it? If so, we can almost rule that out... If not, then yes, with the cooler temps I'm inclined to believe it's TC.
Else, it could be a lean condition brought on (unlikely but possible) by the cooler temps. We really need some logged data to make an informed recommendation.
Old Dec 8, 2008 | 06:18 PM
Mr.Big's Avatar
Mr.Big
sounds like belt slip as well... to many variables without logs...
Old Dec 8, 2008 | 06:21 PM
EdwardETraylorIII
Mr. Big's observation makes me ask another question - Is this bog during transition from vacuum to boost or when you are already well into boost? You do have a boost guage that shows vacuum, right? That's the only way you'd be able to answer the question above.
Old Dec 8, 2008 | 06:22 PM
csun213's Avatar
csun213
I don't think the belt is slipping because my boost gauge shows the boost at 6.5-7psi.
I just had my belt tensioner replaced due to a bad tensioner.
I will get someone with a computer to ride with me and I hope I can get it to repeat.
Old Dec 8, 2008 | 06:26 PM
EdwardETraylorIII
Charlie,
Great idea! Get the to use HPT to log the run.
If it's TC we'll see it, if it's KR, we'll see it. At least this will help us rule a few things out.
Old Dec 8, 2008 | 07:34 PM
AVB's Avatar
AVB
Bring my wheel with you to the house and we'll go for a ride while I log. I would say TC for now...
Arnel
Old Dec 8, 2008 | 08:36 PM
HAVAN123's Avatar
HAVAN123
I have an APS Twin Turbo and a couple of months ago I had the same problem. We pilled the spark plugs and found that they were in need of change. since then no more hesitation. worth a look
Old Dec 8, 2008 | 09:54 PM
csun213's Avatar
csun213
OK, it does not hurt to change out the plugs. A cheap fix if it works. Thanks
PS, did you just replace the same plugs or did you change the range?
Old Dec 8, 2008 | 09:56 PM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
I think it's T/C as well!
I have an A6 and it did the same thing!
Old Dec 8, 2008 | 09:58 PM
HAVAN123's Avatar
HAVAN123
i just replaced the same plugs. if they foul again, have your tuner check related sensors that might make the car run rich. good luck
To Bog during boost?
Old Dec 9, 2008 | 10:38 AM
EdwardETraylorIII
I guess it takes someone else saying it before it's noticed.
Old Dec 9, 2008 | 01:57 PM
setxws6's Avatar
setxws6
Converter not locking up or slipping?
Old Dec 10, 2008 | 05:17 PM
rwebcon's Avatar
rwebcon
I do not think it plugs. I had new cooler plugs installed at installation of my SC. There are too many people experiencing the problem for it to all be plugs. I still think it the TC and the computer pulling timing. CSUN213 at 50 miles per depending on what HP and TQ your running wheel spin maybe happen. On my setup there is most defiantly wheel spin, smoke and fish tail at 50 MPH at full throttle. Try turning all the controls off and see what happens.
