Procharger F1-C or TTI TT??
Ok guys whats your opinion on these two. My goal is to make my C6Z get over 800rwhp. Ive been talking to my tuner and he is telling me to go with TTi kit. He said we can do it with the F1 but he said thats more of a race blower. My guy already has a game plan for all the mods and upgrades for the TT. Whats your take on this guys.?
Just want to make the right choice and do my homework before I pull the trigger on an investment of this size. Any Suggestions
Thanks in advance
Thanks in advance
You'll get a lot of info with the search function. We covered this about one every two weeks for several months straight before we started advising folks to utilize the search function.
I make SERIOUS ( think: 1,300 RWHP) power with my APS TT kit, meth, and Nitrous... I'm a fan of the TT setup.
If you have specific questions about the various turbo setups, then I'll gladly help you.
Guest
Posts: n/a
The answer depends on how much power you want to make. Either will make 600hp with ease. Going for 850-1000hp - either WILL require custom work and $$$. The biggest advantage the turbo's have over SC's is boost controllers - read...boost by gear, but the SC will cost less.
Thanks in advance
Thanks in advance
http://www.exoticperformanceplus.com...html?item=1714
Here is a link to this car from my project car section.
http://www.exoticperformanceplus.com...Car.php?car=29 Bob
Thanks Guys. Ed thats some serious power Ive been doing the checking the search engine and getting some info. I just wanted to see what everyones opinions on each one was. My last project car cost me 20k and it never made the track, it caught on fire about a year ago, so im going to donate it to shop. I took a firends advice and well we all know how that goes. I just want to make sure I make the right decision this time. My goal is to run well into the 9's in the 1/4mile. I want to get her numbers over 800rwhp/800rwtq on pump gas.
See a close freind of mine says go with a blower because its more predictable and cheaper/less maintenance. While my tuner is telling me to go with the TTi kit. I value both of their opinions becuase they both know what they are talking about so its hard to decide. I have never owned a FI car. So im just doing my homework this time. I think I might go to a local Corvette show and take a look at all the set ups and see which one I like better.
Ed do you have any footage of your car? Thanks
Guest
Posts: n/a
I would go TT if you are planning on 1/4' drag racing the car. Boost by gear will enable you to hook up much better in first and second gear, while making torque down low for a strong launch. Boost by gear is not as much of an issue for 3rd gear roll-on's. If you have the money to go TT, I would whithout hesitation and not look back.
Do you want low end tq or top end power. Do you want to drive it on the street and be able to touch the pedal @ 2500 RPM and feel like someone kicked you in your behind? If yes, go with TT. If you want a safe and incremental increase of power, go with centri. You can get in trouble with TT when a sudden boost hits you at a wrong time or wrong location and that car becomes explosive, like in a turn or miss judgment of a distance. You need to learn and respect TT on a 427. with Centri it safer but will not feel the same kick in the butt.
I've had them both and I love TT and I like Centri SC.
Just my two cents!
p.s. If you go TT, be sure it's street and part throttle tuned and not just WOT on dyno.
Just my two cents!
Former Vendor
We have a TURN KEY, 1000hp custom ProCharger system we sell and install. I have some pricing listed on our website that is only valid for one more customer.
With that said, we have developed several ways to control power application on either system - turbo or supercharged.
TT has advantages and SC has advantages. It depends on what gets you excited. At the 800 rwhp mark the supercharged route will get you there for less expense and is easy to reverse or swap to another car if you want later...
Vindication- Thats about right lol. Do you have any footage on your vette? Thats about what my tuner said she should make on pump gas. Have you ever taken her to the track?
Zrocks-There are alot of different things that i have to fiqure out. which on is faster in the street and which one in the 1/4? Sounds likew you prefer TT? Any particular reason why?
Atx427- I plan on taking her to the track every once in awhile. My guy does have that boost controller in my set up build. You think TT is alot better?
I plan on keeping her for along time, so durabilty is a concern. I hear blowers put more stress on your engine while TT are harder to maintain.
Thanks guys for the insight
a) I love low end tq for Daily driving. Tap on the gas and see the front of that car lifts off.
b) With Turbo, you get free power. With SC, you take power from engine.
c) I hated belt problems. No belt issue with TT.
d) For some misterious reason, Twin Turbo has a nicer ring to it than Supercharger or blower.
My second choice would be:
a) Kenne Bell - TwinScrew. Very efficient and less heat
Third choice:
a) Maggie - TVS 1900 or 2300. Not as efficient as KB, but still great.
Last, I'd go with Centri. A&A has the best kit!
If you have never had FI, I'd be very careful having Twin Turbo on a 427 engine with light weight. People will mess with you and you could easily loose control. That would be an important consideration to go with Centeri, having safe power delivery!
Good luck!
Guest
Posts: n/a
My First choice would be either TTIx or APS:
Third choice:
Good luck!
Third choice:
Good luck!
BJK
