C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Engine Horsepower/Torque?
Old Feb 19, 2009 | 11:53 PM
mmyer0's Avatar
mmyer0
Default Engine Horsepower/Torque?
I would like to know... what is my engine horsepower and torque?
I have an '07 A6 LS2 with a P1 Procharger supercharger, Kooks long tube headers w/hi-flo cats, X-pipes, Corsa Sport exhaust, 60lb injectors, Kenne-Bell booster pump and NGK TR-6 plugs.
The dyno results were: 475 RWHP/ 439 TQ
So, what do the dyno results translate to at the engine flywheel?
Old Feb 20, 2009 | 12:15 AM
vettesweetnos's Avatar
vettesweetnos
560-565 hp and 520 tq. Thats 18% drivetrain loss. Prolly pretty close.
Spying Beast's Avatar
Spying Beast
About 15-18% more than your RWHP.
Old Feb 20, 2009 | 05:22 PM
rwebcon's Avatar
rwebcon
A good tune by a professional is very important.
Old Feb 20, 2009 | 06:06 PM
saplumr's Avatar
saplumr
Forget the engine HP. You should find out why your wheel HP and torque are so low. You should be somewhere around 500-525 rwhp and 480-495 rwt.
Old Feb 21, 2009 | 09:52 AM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I agree, there should be no reason why this car should be 500+
Who tunes the car?
Old Feb 21, 2009 | 02:57 PM
thegame's Avatar
thegame
Get a dyno tune by a reputable tuner ASAP
Old Feb 21, 2009 | 03:43 PM
BADZ's Avatar
BADZ
Old Feb 21, 2009 | 05:44 PM
07MontRedcp's Avatar
07MontRedcp
Wouldn't it be prudent to ask what the boost psi is and whether a Mustang dyno was used before questioning the quality of the tune. Just asking.
BJK
Old Feb 21, 2009 | 06:20 PM
saplumr's Avatar
saplumr
BJK
My dyno numbers according to some would be 30+ higher on one of the other dynos. But I look at it as some using certain dyno numbers as a crutch.
Old Feb 24, 2009 | 12:21 PM
mmyer0's Avatar
mmyer0
I'm only running 7lbs of boost for longevity and I did have it tuned by the most reputable tuner in the Phoenix area. I don't know which type of dyno was used, so, figure the one that gives the lowest numbers, OK?
Old Feb 24, 2009 | 03:00 PM
NYC6's Avatar
NYC6
You're pretty close to my #'s. I have an 06 A6 with similar mods to yours and I have a Vortech T trim with a safe tune making 505/440 to the wheels. In the near future I'll turn up the boost.
Old Feb 24, 2009 | 03:39 PM
07MontRedcp
Seeings how we're both in the same general area I will throw out what I've found out.
I don't know who you are referring to when you say "most reputable tuner" but I have communicated by email with a tuner that uses the name Nic D and here is what he said about my dyno tune that was done in S Cal in the winter when it was 40* in the dyno bay: "That's some really good power for the level of boost and the timing. I don't know if I would expect that much power here in AZ, everything seems lower here in AZ compared to the
rest of the US."
When you get a tune here you have to take in to account the VERY high summer temps, especially if you are not using meth/alky. There are those who choose to run a winter tune and then switch to a summer tune for June thru September.
BJK
Old Feb 26, 2009 | 07:01 PM
mmyer0's Avatar
mmyer0
I don't know who you are referring to when you say "most reputable tuner" but I have communicated with by email with a tuner that uses the name Nic D and here is what he said about my dyno tune that was done in S Cal in the winter when it was 40* in the dyno bay: "That's some really good power for the level of boost and the timing. I don't know if I would expect that much power here in AZ, everything seems lower here in AZ compared to the
rest of the US."
When you get a tune here you have to take in to account the VERY high summer temps when doing a tune, especially if you are not using meth/alky. There are those who choose to run a winter tune and then switch to a summer tune for June thru September.
BJK
Yes, Nic D is the tuner I used.
Also, it is my understanding that you can use the 18% drivetrain loss for stock, however, when you increase your hp/tq the drivetrain loss doesn't increase, it remains the same irreguardless.
Old Feb 27, 2009 | 08:54 AM
JSB LS3's Avatar
JSB LS3
475 is not THAT low on a load-bearing dyno through an automatic tranny in a state with a generally hot climate.
To Engine Horsepower/Torque?
