C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Free Supercharger Install When Forging!!!
Old Mar 11, 2009 | 02:08 AM
Randy@RaginRacin's Avatar
Randy@RaginRacin
Supporting Vendor
Default Free Supercharger Install When Forging!!!
We have been doing several Stage 5 setups here at the shop. We do suggest forging the motor when doing superchagers and our full stage 5 setups. For a limited time we will be running a special. If you want a Supercharger, Cam, Clutch, Heads, Headers then now is the time to save the extra expenses. This will all be done at no extra charges when you forge your shortblock with us.
Each person may want their motor built differently so please contact us for additional information so that we may build the motor to Feed Your Rage properly.
This is good for ECS and A&A Kits. When doing this setup all parts must bought from Ragin' Racin'( Of course I will give you package pricing on the parts as well)
__________________
RAGIN RACIN
Randy Leger
337-278-8397
sales@raginracin.com
http://www.raginracin.com
Old Mar 11, 2009 | 11:31 AM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
Old Mar 11, 2009 | 12:06 PM
Tonycpa's Avatar
Tonycpa
PM sent
Old Mar 11, 2009 | 01:33 PM
cencalc6's Avatar
cencalc6
WoW!
Old Mar 11, 2009 | 01:35 PM
BADZ's Avatar
BADZ
email (gmail) sent Shawn
Old Mar 11, 2009 | 03:05 PM
Way2Slow's Avatar
Way2Slow
Very nice deal
Old Mar 11, 2009 | 03:46 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Bump for a fellow Louisianaian. Great deal
Old Mar 12, 2009 | 03:08 AM
Randy@RaginRacin
Supporting Vendor
All pms answered. We may have some high boosted C6's coming out of Ragin Racin Real Soon.
Old Mar 14, 2009 | 10:38 PM
BADZ's Avatar
BADZ
Waiting for my returned email bro.....
bump...
Old Mar 14, 2009 | 10:56 PM
Randy@RaginRacin
Supporting Vendor
Sent it out this morning.
Old Mar 15, 2009 | 10:40 PM
lfsglass's Avatar
lfsglass
What is included in this $6600 forged upgrade?
Old Mar 15, 2009 | 11:44 PM
Distilledgt's Avatar
Distilledgt
Old Mar 16, 2009 | 12:02 AM
Zo6BEAST's Avatar
Zo6BEAST
WOW
Old Mar 16, 2009 | 07:51 PM
lfsglass's Avatar
lfsglass
Old Mar 17, 2009 | 12:58 AM
Randy@RaginRacin
Supporting Vendor
Ragin Racin Block Preparation
All internal parts are de-burred, hand washed and inspected. New Forged Pistons, pins and connecting rods are pin fit to specification Crankshafts are computer balanced to within .5 grams. Crankshaft bearing surfaces are micro polished.
Engine blocks are align hone checked and re-machined if needed. Deck surfaces are machined in reference to the crankshaft centerline Blocks are hand de-burred, bolt holes are checked and re-tapped
Blueprint and Assembly
Includes verification of Ragin Racin specifications of:
Cylinder bore diameter
Cylinder wall taper
Piston diameter
Deck height of block
Bearing clearances
Crankshaft end play
Piston to valve clearance
Bolt torque specifications
Lifter bore diameter
Piston skirt taper
Piston to wall clearance
Piston ring end gap
Rod side clearance
Valve adjustment
Degree the camshaft
Old Mar 18, 2009 | 09:17 AM
BADZ's Avatar
BADZ
Shawn, I'm assuming that with this build: (NEW) not stock? Or you are using the stock crank and providing new rods, pins and pistons?
"New Forged Pistons, pins and connecting rods are pin fit to specification Crankshafts are computer balanced to within .5 grams. Crankshaft bearing surfaces are micro polished."
Old Mar 22, 2009 | 08:39 AM
Randy@RaginRacin
Supporting Vendor
Depends on you, but I thing we got this settled. Your car is sitting pretty at our shop. When you get it back it will be an animal!!!. Thanks Jeff
To Free Supercharger Install When Forging!!!
Old Mar 22, 2009 | 09:42 AM
BADZ's Avatar
BADZ
yes, we did bro.
Old Apr 7, 2009 | 02:06 AM
Randy@RaginRacin
Supporting Vendor
ttt
Old Apr 7, 2009 | 02:21 AM
EdwardETraylorIII's Avatar
EdwardETraylorIII
Ragin,
Looking at your list of parts during a forging, it looks like you reuse the OEM crankshaft?
If so, I think this is pretty smart on the LS7 platform. The LS7 crank has been proven beyond 1500 BHP (with forged rods and pistons!)!
