APS TT- what size turbos?
Maybe a couple mm, may have to talk to Forced Performance or one of the turbo suppliers to get the scoop.
I'd do it if it were possible, but I have not talked to them yet.
I've dealt with Forced Performance for a set of turbos a few years ago, very knowledgeable, you might want to give them a call, or ATP Turbo, another supplier of Garrett turbos.
When at low RPM's or not on boost, the car feels and sounds the same. Scared to get on full boost, but when I do it doesn't feel/sound right, hopefully I'm just being paranoid. What are your thoughts guys?
Spacer desc: diameter smaller than a dime, 3/4 inch thick, copper colored, no oil or residue when found, and there's some chips/nicks on the spacer.
Getting my car on a lift this weekend to start the process of elimination.
1) checking air filter to see if anything made through the turbos from there
2) removing the pipe after the turbos to see if there's any signs...
Hopefully someone knows where this piece may have came from or at least tell me my turbo is not shot.
