New-HD Tensioner for the A&A brackets!
Hi guys, I've sold quite a few of these in the past while and figure I would share this with you guys. Basically what it does is replace the stock tensioner with a HD truck version. This truck tensioner is a "bolt together" tensioner versus the stock stamped piece-this prevents flexing and makes sure the belt tracks accurately. It also takes "twice" as much force to open over the stock tensioner which in turn puts more pressure on the belt especially around the crank pulley where all the slip happens. All it takes is for you to drill and tap 1 hole and it's on.
Cost is $120 plus shipping.
I also have 6061 hard anodized black pulleys to replace your stock pulley's. There available in 8 or 10 rib configuration.
Cost is $100 each or 2 for $180.
I upgrade the tensioner on all the cars and upgrade the pulleys to everyone who's looking to make big power!
PM me with any questions-thanks!
This is the tensioner that came on my bracket and other A&A brackets I've installed. It's fine on 6 ribs, but I've found on 8 ribs when your going all out, it's a little week. I've sold the HD one to several guys who were breaking the stock unit or were watching boost flutter up top-this really helps fix that
That is the tensioner Andy currently uses. I was having problems with my 8-Rib set-up and bought Arun's tensioner to find my belt now tracks much better with no excess where as I was seeing from the kit tensioner arm bending.
Now that is a lot of brass air fittings http://www.liangdianup.com/subpages/airfitting_1.htm there is just about every type
of air fitting that you could want. Wholesale prices too. I guess these could be used as small water pipe fitting also. I
used some of the parts to make my babington wvo burner.
1 Post
How much stronger would you think yours is?
Mike
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes
You definately should not have any belt slip from the ECS tensioner, we take a hefty tensioner, and replace the internal spring for more tension on top of that. I would make sure the tensioner is in it's fully openeed possition at rest.
Take our tensioner tool and open the tensioner all the way to see where yours is presently sitting. Or you can send a picture of your tensioner and I'll take a look at it for you.
There is definately something off, and you have no need to purchase any other drive systems, or different tensioners, we have countless logs of cars with standard 8 rib belt drives perfectly holding boost to low nine second passes.
PM me if I can help get the belt taken care of.
(sorry to highjack your thread Arun!!)
Bump...for a great product and a super nice guy.
Thanks Arun, I used the part number you gave me, made the spacers similar to what you have pictured here, and bolted it on. It worked out perfectly! I'm glad you did the leg work on this one, it saved me a lot of time.
