C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Is boost-a-pump enough?
Old Apr 10, 2009 | 03:56 PM
TinSecondRice's Avatar
TinSecondRice
St. Jude Donor '08-'11
Default Is boost-a-pump enough?
I have a 402 in my car and am thinking about putting a nitrous kit on it. I was wondering if a boost-a-pump would be enough to handle the fueling for the car on say a 150 shot? Or will I need a different pump?
Old Apr 10, 2009 | 04:11 PM
EdwardETraylorIII's Avatar
EdwardETraylorIII
Gil,
What size injectors are you running on your 402? What kind of RWHP numbers are you laying down?
I'm inclined to say, "yes" to your question, but I need a couple more details before I can speak definitively.
Old Apr 10, 2009 | 04:14 PM
TinSecondRice
I need to just start pm'ing you when I have questions
I have 42 lb ford green top injectors. The car put down 465 whp through the auto w/a stall.
I thought I had read on here before that the z06 pump was an upgrade? Is this true? If so, is it bolt in or is there more to making it work? The transmission and all is out right now, so it would be a good time to upgrade if need be. I plan on going FI when I graduate in December.
Thanks!
Old Apr 10, 2009 | 04:31 PM
EdwardETraylorIII
Gil,
I honestly don't know if the non Z06 C6 has the same pump as a C6Z.
Since the rear cradle is all out right now, go ahead and upgrade the fuel system. It's a negligible ($1500) cost and will save you a lot of heartache down the road (since you plan to go FI soon)!
Old Apr 10, 2009 | 04:46 PM
TinSecondRice
I just looked up the part #'s, and they are different for z06 vs regular c6. I may look more into doing this...
Old Apr 10, 2009 | 05:02 PM
EdwardETraylorIII
Just put two Z06 pumps into the canister and be done with it
To Is boost-a-pump enough?
