Need help from 1000hp guys and pro's on project.
I getting prepared for 1000hp project financially and mentally guys i need some help from the Pro's cause i not one please don't be afraid to chime in cause i am in process of learning everything will be appreciated.
LSX Block (maybe 434ci. inspired by Dallas performance Amazing Build )
Heads ???(All PRO LSW pricey vs ET Ls7 not sure yet)
Pistons ??? (haven't decided yet with CR and pistons brand)
Callie's Magnum Crankshaft
Oliver Billet Rods
TTi Kit (maybe from Turbo Technology if they work on custom one)
Full Drivetrain Upgrade from RPM with RPS Triple Disk Clutch.
I know the list is short for 1200hp project am just listing the main parts but ending bill is around 60K for now.
The stuff I having second thought about.
6MN or 4l80e ( I personally love 6MN )
Ls7 Intake or Sheet metal
I just don't know what to get or benifits from is going to be worth the upgrade.(Dallas performance 434lsx build elbow intake looks interesting)
Rashed
Oliver Billet Rods
Rashed
I am not one of the 1000hp gurus around here but just to let you know. I spoke with the guys from TTI and they told me specifically that their system will not get to or over 1000rwhp. So if that is your goal then you will need to look at the APS or some customized system to reach that goal.
There rest of your list looks very sound. The All Pro heads are what I plan to go with when I get to the point of building a big cube FI motor. But the way I had pieced together their heads would be $7K+ just for the heads. ET heads are not bad and i have seen come in much cheaper. For around 1000rwhp ET heads will be fine.
For the pistons my personal prefrence is Diamond and then having them coated to deal with the heat a little better. CR depends on your plans for the car. if you want to mostly run around on Pump 93 octane no meth or only meth as a safety measure or for when you really want to turn up the boost then I would say 9:1 or so.
Like I said the guys you already know on here; Taylor, EdTraylor, ATX427, Atomicfusion, and MANY others I am sure will stop in to give you their input as well.
Crazy build you have on the way!
EdwardTaylor and AtomicOrange are a couple of members who are pushing > 1000 RWHP. They both seem to be great guys who are always willing to help out. I imagine one/both of them will see this thread and pop in.
I agree with your statement regarding the MN6. Although an auto might be more suited for such a high-power build I think running an auto on such a setup would take a lot of the fun and enjoyment out of it. Tearing it down a 1/4 mile track with an auto sorta seems to defeat the purpose?
I am not sure if you have your heart set on a 1000+ setup or not but for a whole lot less money (probably tens of thousands) you can build yourself a car that will have 700 or so RWHP.
I know that All Pro heads are bit pricey but i try to keep them my priority i just want to know if ET heads are good for 1200rwhp.
I don't really care if they rip my vette apart to do a custom kit cause i am doing this once Turbo Technology is 2 hr drive away from me so i will see if they can work a custom kit for my application rather than getting standard kits out there I'll keep Diamond Piston's as an option.
I hope that 1000rwhp will chime in and give some info
MN6 are fun and i rarely drag my car maybe twice a year but i want to know if beefed up MN6 from RPM can handle this kind of hp with DR all time that's my worry.
I just worried on what 4l80e will be running high rpm on highways cause it will be kind of a DD and defiantly like to travel with my car.
Oliver Billet Rods
Rashed
Oliver Billet Rods
Rashed
Since we have been at these style builds here often lately, maybe I can be insightful. (Maybe )
LSX block, the only issue we have run into is weight, but in the long run longevity, the iron block will hold up very well. Cubic inches wise, we have seen a nice difference from Marks, 427 to current 434 , the 434 spools up the turbos very hard now, combined with the cam changes.
Personally if your going with any turbo GT35 or smaller, there is no need for the larger cubic inch, the 427 will spool up nicely and rev out well. Just my .02
As for heads, Kerrys heads at ET performance are industry leaders, amazing technology in his heads, I have been to his facility, and seen the start to finish build of the LS7 head he created, and it is mind blowing the amount of time and money in R&D on his heads. We have used them to over 1200 horsepower several times now, and he builds them right. ET's pricing is also incredible cheap for the product you receive. Combine their heads with some Titanium intake valves, and Inconel Exhaust valves (gonna need some coatings done as well at these power ranges) and you will have a very capable set of cylinder heads.
As for pistons, just consult with a manufactor you trust, we have used Diamond, and JE with good sucess, Katechs new pistons are top of the line as well. I would target a 9.2 to 1 compression ratio.
CrankShaft, the magnum from callies is a very nice piece, but if you thinking of saving a few dollars the dragon slayer will work nearly identical, albeit there are some neat stroke to rod ratios you can create with the magnum cranks.
Rods, The Olivers are nice rods, and will hold well. Also consider Carillo's if your looking for a strong forged rod. Just make certain that you are getting a proper rod bolt, we choose A1 bolts.
Drive train, well RPM does make proper set up, add in a Quaife as well, and some good out put shafts (trans and diff) and you will be good. As for a clutch, I would stear away from the RPS triple seen too many issues with such a high dollar unit. Consider the Exedy or maybe the Tilton.
The automatic 4l80 set up is fairly invasive to the car as well ( lots of cutting ), but will offer you the ability to give the chassis a much smoother transition between gears, and a smoother launch think slingshot! Just remember this is invasive, and some people will not mind, others will.
As far as other pieces, what are you thinking about on a fuel setup?
Drive train mounts (Pfadts work very well)
Intercooler, going to need a custom unit more then likely?
Radiator, dewitts?
I could think of a lot more what ifs, but if you like give us a call or PM, and I can build you an estimate that would show you some more real numbers to a build like this. There is a lot to these builds, and Good luck
-Brandon
Former Vendor
PM sent.
As far as the block I personally used World Warhawk to save weight as the turbo system will be adding a fair amount of weight over the nose as it is.
Rashed,
don't forget the fuel system that you will also need to support your power goals... and the 434 LSX is the Perfect platform for what you are after...
Go with a 450 CI build (if you go with the LSX block). You'll make more power on pump gas and the turbos will spool INSTANTLY! Lot's of choices for heads in the six bolt config.
If money is no object, consider the short deck warhawk option!
Go with the 4L80E. Just get it over with and enjoy it!
Don't rule out the APS kit. It's quite an incredible kit.
Add a meth kit to your list of things to buy!
Best advice.... Pick a top tier shop THAT YOU TRUST and discuss the plans accordingly. You will get to many answers here and all you end up is a bunch of opinions from people who are NOT going to build your car. I mean if you look at some of the top cars here ...most of the people had these discussions with their builder.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,091 Likes
You can easily reach your goals with your mod list, there will be a few other things that will be needed, but we have made basically that exact package already and exceeded the "maximum torque" for our dyno, which is aproximately 1150 ft lbs and had about 5 more pounds of sustainable boost left
Good luck with it.
Good luck with it.
Former Vendor
Sounds like you are on the right track! The best advise I've seen is to pick the shop you plan to use first, and then develop a build plan based on their experience. I know we could save some of our customers a LOT of money and time if were we able to do it our way from the start.
Rashed,
Radiator, dewitts?
-Brandon
Radiator, dewitts?
-Brandon
I look in and Clutch's that you talked about see the the other options give me and for 4l80e i will see if its best option for me.
And for APS kit i not ruling them i just want something little bigger and custom and for meth kit i go for it for insurance.
450c.i is somthing i like to do if its possible with LSX i been hearing that alot of cubic inch isnt best choice for F/I builds
but well that that also depends on shop i work with but you never know
454ci is what going to happen
Former Vendor
I suggest keeping it small cube, maybe 4.130 or 4.15x bore tops to keep it rebuildable. Max effort build on the first shot can cause many issues should something go wrong. We all know how that goes.
Don't forget the Driveshaft Shop driveshaft to replace the guts of your torque tube.
I am running the Textralia Exo Triple and am very happy with it. They're quoting 1200ftlbs torque capacity (real world), but it's also a matter of vehicle weight too. 1200ftlbs with a 8000lb truck is much different than a 3300lb car.
Get your pistons gas ported and annodized to help with strength and blow by. It's a little extra $, but good insurance.
I'm on budget Patriot heads and LS2 intake. The power mentioned in my sig. was the 8th pass on the dyno in an hour at Dallas Performance. Heat soaked and worst case scenario. The pass before, my Textralia twin was letting go, but it made 40 more rwtq, which would have put me closer to 960rwhp. Just the difference in displacement would put me over the 1k mark.
