If I use the windshield wiper water tank for a meth system, is the tank thick enough to run an NPT tap to feed the pump? Also, what temperature sensor should I use since I will be spraying after the MAF sensor?
Yes, as already covered, the W/W reservoir is fine for tapping! I would also advise you to coat the threads of the bulkhead in a methanol resistant sealant!
I've ordered the 87 Buick GN sensor and pigtail. Is the calibration for this sensor the same as the one in the stock MAF or does the table in the CPU programing need to be modified?
