C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Will a Procharger C6 = Z06 performance
Old Aug 1, 2009 | 02:35 PM
trapp's Avatar
trapp
Default Will a Procharger C6 = Z06 performance
I owned a 07 Z06 and sold it and bought a 09 C6 M6 Z51. I did it because I wanted the open feel of the top off option. But I missed the ***** out performance of the Z06. I added Kooks header and Cats with a Vararam intake with tune (step one). Other then the sound of the car I could not tell much of a difference. I will be getting my car back on Monday..they just added brake upgrades and a procharger with tune. Vararam was removed. I was wondering what numbers to expect as far as 0-60 1/4 mile etc...will it be comparable to the Z06. I was roughly 0-60 3.7 and 1/4 11.75 at 123. With my C6 Z51 I saw 4.1 and 12.5 respectfully. My RWHP of the Z06 was 475 after tune and KN intake. The C6 was 385 after tune and headers. (mustang dyno)
Any Thoughts
Trapp
Old Aug 1, 2009 | 02:54 PM
OneBadZ06's Avatar
OneBadZ06
St. Jude Donor '08-'10
My guess.
Your blown C6 will be around 570 rwhp @ 8/9 psi and while you should not expect a big improvement on the 0-60 time compared to your Z time (3.6 sec), your 1/4 will be closer to the low 11s, if you hook up.
Old Aug 1, 2009 | 04:52 PM
trapp's Avatar
trapp
Originally Posted by OneBadZ06
My guess.
It will be more to the 6psi then 8-9. I wanted to keep my internals stock. Anything above 6psi they recommend better internals to prevent engine failure. I should be around 500-520rwhp.
Old Aug 1, 2009 | 04:57 PM
Slvr08Z51's Avatar
Slvr08Z51
With my LS3 car, cam, LT's meth @ 7psi, making 604rhwp... It runs away from H/C Z06's..
Old Aug 1, 2009 | 06:19 PM
speedydog5's Avatar
speedydog5
I have a 05 A4 vert with p1sc1 running 7psi stock internals, and only corsa catback and i,m at 500 rwhp on mustang dyno(that was with old gas in it), havent got to track yet(still got runcraps just gonna burn through them before i get somthing better) but i was able to pull from a Z at a 20 mph roll you should b happy
Old Aug 1, 2009 | 07:05 PM
EPP's Avatar
0EPP
Former Vendor
http://www.exoticperformanceplus.com...Car.php?car=59
The LS3 heads love boost, check this one out. Bob
Old Aug 1, 2009 | 07:26 PM
MetallicaMatt's Avatar
MetallicaMatt
good switch imo
I'm pushing 13psi on stock internals, other than a cam!
Old Aug 1, 2009 | 08:51 PM
greekc6's Avatar
greekc6
yea pretty much you can make more than enough power to outrun a z06 safely. the only issue youll hit prob is traction. a paxton could be another alternative and maybe even cheaper
To Will a Procharger C6 = Z06 performance
