C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
still overheating
Old Sep 17, 2009 | 01:39 PM
bomariam1's Avatar
bomariam1
Default still overheating
ok, after the dewitts the vette is cooler and AC is cooling.
but it's still overheating on stop and go heavy trafic, but when in P/N it's even cooling
I know that I have to add the dewitts fan, but why it's cooling in P/N!
and overheating when idleing in gear.
any Idea?
Old Sep 17, 2009 | 02:08 PM
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
what kind of water / oil temps are you seeing?
Old Sep 17, 2009 | 02:22 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
You could try a seperate trans cooler with a fan, placed prior to the radiator, so it cools the trans fluid before it goes into the radiator. We have seen large temp drops in coolant from doing that.
Old Sep 17, 2009 | 03:48 PM
Ragtop 99's Avatar
Ragtop 99
Are your fans spinning the right direction? Make sure they are not fighting the air coming in.
Old Sep 18, 2009 | 10:43 AM
CPG1962's Avatar
CPG1962
Default Read thru this link - carefully!
http://forums.corvetteforum.com/c6-f...post1571538033
I have made some changes along the way but rest assured. If followed your cooling issues will disappear.
Old Sep 18, 2009 | 01:31 PM
bomariam1's Avatar
bomariam1
I am sure to try this, I will tack the vette to the track next month.
so do you think it's from the tary?
what about the timing?
and yes I like my fog light very very much, I saw it before but I couldn't think on doing it. sorry the vette with the fog rooock man.
Old Sep 18, 2009 | 02:40 PM
EPP's Avatar
0EPP
Former Vendor
http://www.exoticperformanceplus.com...html?item=1452
A hood like this one would help do keep the underhood engine temps a lot cooler. Bob
Old Sep 19, 2009 | 04:23 AM
bomariam1's Avatar
bomariam1
it will cost me $2k to ship it only
Old Sep 19, 2009 | 07:08 AM
CPG1962's Avatar
CPG1962
I understand 100% but when the engine compartment is packed 100% with intercoolers, larger fans (I have the duals), etc. It is the only "fresh air" I could find. If you have removed your leafsprings you have a spot underneath to mount a cooler. I went with a round in-efficient gadget but it does work. I may switch it out with an Earls straight stack if I encounter any more problems.
For a quick fix I would change out the two pin connector (to handle more amps) and up your fan speed and frequency.
Old Sep 19, 2009 | 07:13 AM
CPG1962's Avatar
CPG1962
100% - I have a dewitts but had the trans cooler bypassed and the temps dropped. The coolant was rising from the transmission heat transfer.
Old Sep 19, 2009 | 01:05 PM
rAte's Avatar
rAte
First, I am not am expert, but had a BMW that did the same thing. Pulled a couple degrees of timing and a new water pump fixed everything. Second, this screams tune / timing. Stopped in traffic it should be closed loop, has the tuner adjusted timing on the closed loop maps? Good luck, it will all come right in the end.
Old Sep 21, 2009 | 02:25 PM
bomariam1's Avatar
bomariam1
I sure hope so, looking in timming sence it's easer to go for.
and CPG1962, I still have places for cooling, didn't try the fan yet, still trany cooler (smal one with fan form b&m) may solve it.
Old Sep 21, 2009 | 03:26 PM
CPG1962's Avatar
CPG1962
I still beleive you will find changing out the 2 pin connector and then having your tuner pump up the fan speed, cycle time, and frequency is the easiest way to go. The 2 pin connector is north of the Fan control box (6" x 6" x 2" approx). The 2 pin connector is blue in color I beleive and is the main power source going into the fan area. You can make one out of aluminum and then wrap it with shrink tubing or mastic tape. The fan is set at 85% from the factory and comes on, stays on for a duration,a nd then turns off. I beleive there are two temp "zones" the fan comes on and off. These can be adjusted with tuner box. Crank up the fan to 95% and allow it to come on earleier and run longer. The difference SHOULD be tremendous.
Old Sep 22, 2009 | 09:48 AM
bomariam1's Avatar
bomariam1
I have the fan on 100% from 91c,
Old Sep 24, 2009 | 06:22 AM
CPG1962's Avatar
CPG1962
NO ****! Do you have coil overs? If yes, place a cooler where your leaf springs once where. My car creates ALOT of heat with HP and forged pistons. I have gotton it under control. You may HAVE to pull those foglights. Best of luck.
Another tidbit I just learned was the from A&A. I have a PC D1SC with a PC intercooler. You may want to switch to the A&A intercooler IF you run std procharger unit.
Old Sep 24, 2009 | 06:27 AM
CPG1962's Avatar
CPG1962
You better watch that connector - it WILL melt at 100%!
Old Sep 28, 2009 | 03:11 AM
bomariam1's Avatar
bomariam1
do you think it will effect if I made it 90%.
Old Sep 28, 2009 | 05:48 AM
CPG1962's Avatar
CPG1962
Eventually - Yes
Old Sep 30, 2009 | 04:00 AM
bomariam1's Avatar
bomariam1
Eventually - Yes
I will reduce it to 90% and I hope it will work, and I will send update after that,
thanks.
To still overheating
