C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Interesting coolant issue
Old Oct 6, 2009 | 06:42 PM
Motorhead-47's Avatar
Motorhead-47
Originally Posted by DOUG @ ECS
Not when you do an operating system upgrade, it allows the fan to come on at 170ish. Although this car was done a long time ago, I'll have to check his file. 100% is loud, (although we do not set fans to 100%) we wouldn't set it to that unless it saw high temps, where cool outweighs noise.
OP asked about possibility of setting the fan to 100% full time...I didn't mean to imply you would have.
Old Oct 7, 2009 | 12:13 AM
drivinfast's Avatar
drivinfast
mine did the same thing, the twin spall fans were staying on before after car is shut down.
i will need to test tomorrow but i have left the AC off now the past few times i have driven it and then shut the car down and the fans stay off
Old Oct 7, 2009 | 12:48 AM
fperra's Avatar
fperra
Has anyone ever just taken the fan connector out and soldered the wires together? Seems like an easy solution.
Old Oct 7, 2009 | 01:03 AM
drivinfast's Avatar
drivinfast
there are at least 2 threads on this solution, gotta use terminal blocks instead.
Old Oct 7, 2009 | 10:12 AM
C6_blackhawk's Avatar
C6_blackhawk
I'm tracking you now. Since my ground wire died on me about a year ago, I bet it melted the connector. I'll take it apart today and see what carnage awaits. What is the connector there for anyway? Why isn't it just hard wired? Can anyone see a reason why I can't just use a terminal block/ barrier (http://radioshack.com/product/index....ductId=2103228) to link the wires together?
Is there a fuse built somewhere in the wiring to protect the controller itself? If so, why does the connector melt? If not, maybe I should wire a fuse in there.
