What's the problem when u burn the fuse on the msd? I did this weekend and I lost all fuel and engine shut down.
Did you replace the fuel pump fuse from a 20A to a 30A? It'll be in the fuse box in the engine bay. You should have a spare 30A, so just do the swap. This should have been done upon installing the BAP.
I blew my BAP inline fuse awhile back too. It was only a 20A fuse though. I replaced the inline fuse with a 30A but left the stock 20A fuse under the hood. Haven't had any problems since. I would check the way the BAP is spliced into the stock wiring under the drivers rear wheel well. You definately want to solder those connections. Solderless butt connectors do not work well.
