C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
methanol injection without tuning
Old Oct 15, 2009 | 09:48 PM
james2292's Avatar
james2292
Default methanol injection without tuning
Is it safe to run methanol injection without tuning
I plan to eventually get tuning done
I will be using Boost juice which is 49% meth 51% water
Car is a ls2 with a d1
thanks for the help
Old Oct 16, 2009 | 01:23 AM
Taylor@DallasPerformance's Avatar
0Taylor@DallasPerformance
Former Vendor
thanks for the help
Yes but it will do nothing for power until it is tuned. In fact you could easily loose power if you use too much.
Old Oct 16, 2009 | 02:29 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
depends on how your tune is setup. if its setup to pull timing when its hot, then when you spray the meth, and temps go down, it wont take any timing out, increasing power.
but it would be smart to put it on a dyno for safety, if its wrong, KABOOM
Old Oct 16, 2009 | 10:38 AM
pprice's Avatar
pprice
It would be about like running along side the interstate blind folded.
Just a tip, windshield washer fluid is about 50/50 meth/water
Old Oct 16, 2009 | 10:50 AM
NYC6's Avatar
NYC6
I've read here on this site that just lowering the intake charge temp(even w/o tuning) will give a bump in hp. Would like to know the real deal myself.
Old May 7, 2010 | 06:18 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
I believe that if you car is currently tuned and by adding the kit it won't affect. If it's hot out, Meth/water cools the charge and the computer automatically adjusts timing.
Old May 7, 2010 | 06:51 PM
07MontRedcp's Avatar
07MontRedcp
Check out this thread: http://forums.corvetteforum.com/c6-t...lications.html
Lots of info.
BJK
Old May 7, 2010 | 06:57 PM
duff70's Avatar
duff70
if the meth is after the intake temp sensor it wont read the lower temps. it will richen up your afr. but if your car is too rich you will lose power. the car will bog down.
To methanol injection without tuning
