C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Stock LS3 HP Capability
Old Oct 21, 2009 | 11:10 AM
adam205348's Avatar
adam205348
Default Stock LS3 HP Capability
I am about to install twin turbos on my 08 LS3 Coupe. I want a complete pump gas tune with no meth at 600rwhp which I dont think should be much of a problem. But then I want a C16 tune and want to know what the limit should be on HP to keep the motor together. I have seen numerous people with LS2 and LS3 motors running pump gas and meth making 750rwhp. So I am looking to try to make 800+rwhp on a full C16 tune and if need be Meth injection as well. I have not seen anyone atleast post up that they are running a full C16 tune and what power they are making. Anyone have any input on what the stock pistons, rods, and crank can handle?
Old Oct 21, 2009 | 11:32 AM
BADZ's Avatar
BADZ
It's all in the tune. There are several high hp guy's running around but keep in mind that the rod bolts and cast pistons are the week links in the stock bottoms and once they go then normally it gets the block as well. But then again, some have 1000's of miles and never had any problems.
Mr. Big is an example but his c6 is tuned by one of the best!!!!
Old Oct 21, 2009 | 12:15 PM
adam205348's Avatar
adam205348
Well I know that part. I am just trying to figure out where I need to stay under with a Perfect Dead On Tune before my pistons and rods give up the ghost.
Old Oct 21, 2009 | 12:21 PM
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
The LS3 likes boost. If Dallas Performance is doing the build, you should have no problem safely meeting your goals.
Old Oct 21, 2009 | 12:31 PM
adam205348's Avatar
adam205348
Thanks ATX. Btw your car sounds a looks sick in person. Taylor brought it out to a gtg a little while back. Do you have it back now?
Old Oct 22, 2009 | 08:04 PM
TRINIC5's Avatar
TRINIC5
The piston are forged so it can handle some boost but the rod bolts are weak, I would be scared to try and make over 750rwhp, that is pushing it to the limit and its not the motor that will be the big problem but if it broke while hitting top speed and oil blow on the tires, then you will break instead of only the car.
Old Oct 22, 2009 | 09:26 PM
newschool's Avatar
newschool
Huh?
Old Oct 22, 2009 | 09:36 PM
jmudreamvette's Avatar
jmudreamvette
He is talking about hitting the wall. I have seen some bad accidents 1/2 to 3/4 track. I am going with a SC soon. When you trap speeds get up there, the risk is greater...
Old Oct 23, 2009 | 08:29 AM
JSB LS3's Avatar
JSB LS3
Stock LS3 pistons are not forged, they're hypereutectic.
Old Oct 23, 2009 | 09:30 AM
aTX427's Avatar
aTX427
No yet - we made a bunch of changes; hood, smaller pulley, a Flip Drive from Cartek and new wheels. If all goes well, it will be on the dyno today or tomorrow for final tuning, then I will let Taylor drive it around for a week. This way he can work out any gremlins that may arise before I pick it up.
Have Taylor do your work. There is no one else around that I would trust more. Good luck with your project.
Old Oct 23, 2009 | 04:07 PM
adam205348's Avatar
adam205348
That's what I was thinking. Wish they were forged.
Very cool, Can't wait to see it fully finished and see some results from it.
Old Oct 23, 2009 | 04:09 PM
adam205348's Avatar
adam205348
I had just seen and heard that the LS3 is a stronger motor than the LS2. I see LS2's making 750rwhp all over the place on the stock bottom end. I thought I might be able to get away with a little more with the LS3 and squeeze out 800 or maybe a little more on a Full Race Gas tune and having the tune dead on. I guess we will have to see.
Old Oct 23, 2009 | 04:25 PM
old motorhead's Avatar
old motorhead
I've been at 672+ since july on my LS3. So far, so good. If wanting more, I'd be inclined to upgrade at least rod bolts and maybe pistons. Upgrading now would be cheap compared to trying to piece together a shattered engine. I know things have been pushed past this successfully, but I also know a motor or two hasn't lasted long at these levels. As pointed out earlier in this thread, a good tune is very important. You need to be prepared to spend a little money if you're playing in this ballpark.
To Stock LS3 HP Capability
