Impeller speeds
the previous reply pretty much answered my question which was also what I was estimating but wanted to see if someone had actually done just that with the same supercharged and the results. So whats your opinion
With all of that said, the F1C is a far superior unit, the power and torque under the curve at the same boost level is superior, and the future potential for more boost is obvious... If I knew then what I know now, I'd have started with a F1C and pulley'd up for lower boost, until I wanted more...
, and much testing on closed course pulls getting the car setup for the mile, I'm soooooooo disappointed that I had to work last moment this October (also thankful to have a job during these times) and missed the mile this go'round... like I said, from my experience on my setup the assumptions that I also shared before testing were not found to be true... just trying to inform my CF brothers of my findings...
I have been running a D1SC for almost 7yrs and had tried almost every pulley sized until it went to max, we had tested the AIT with every pulley and has noticed a big change in temperature everytime we changed the pulleys, today I am running a F1R and had changed the complete system to a water to air cooling system, I am now looking to make over a grand rwhp through a 4L80E transmission without meth but will use C16 for safety.
reference link
That is the max "efficient" RPM. The actual max rpm could be substantially higher.
reference link
I think he was saying find another TT that made 2-300 more hp and torque OVERALL that his did on pump has which was 1,002rwhp/928rwtq
You are saying look at the power under the curve and how it comes up much faster with a TT setup. Not total numbers.
Do I have it right?
I run the same timing and fueling tables on meth/pump as I do on C16, its purely for insurance. Why chance a build that took 3 years to come to fruition, and pray the dude at the pump really put 93 in there? I dont know about you, but Im not putting the destiny of my customers engines in the hands of joe blow at the pump
This thread has gotten a bit off topic, Mr Big knows his stuff when it comes to overspinning, he just wont admit it
