C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
iat break out
Old Nov 8, 2009 | 11:33 PM
excessive81's Avatar
excessive81
Default iat break out
my car is sd and i want to get rid of my old maf as it is a restriction and i would like to clean up the install with less couplers and clamps ect. has anyone used this harness to separate iat wires from maf so can remove maf then just run new 2 wire iat sensor. iat is only reason it is on car at this point. if someone has already done this which sensor are you using. all i have found are press/rubber gromet fit sensors. i figure it gonna need a screw in sensor because of the boost pressure i run
Old Nov 9, 2009 | 12:01 AM
wooden's Avatar
wooden
I am running a press in sensor fitting with 14lbs boost no problems.
Old Nov 9, 2009 | 12:09 AM
excessive81
what sensor do you have?
Old Nov 9, 2009 | 12:11 AM
07MontRedcp's Avatar
07MontRedcp
I got the AEM 30-2010 Air Inlet Temperature Sensor Kit off of Amazon for $52. It will be awhile before I put it in. Do a Google on it and see if it's what you're looking for.
BJK
Old Nov 9, 2009 | 12:37 AM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Just get a sensor and grommet from a 97. Drill the hole just under the size of the grommet. It will never come out.
I also just use an OE IAT harness from the same year. Cut the wires and solder in the new ones.
This is probably the cheapest way to do it and it's nice and clean if done properly.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Old Nov 9, 2009 | 08:20 AM
Fast06Z06's Avatar
Fast06Z06
This is the way I did mine.
Old Nov 9, 2009 | 08:51 AM
excessive81
i dont want to cut the harness just incase some day there is a maf for big power guys or i want to pull my motor and drop a crate motor back in it to trade or sell so i am ok with the $30 harness. gonna pull all the maf wires out of clip so it just be iat wires coming out of it anyway. thanks for the sensor info. but i cant find any act pics of the aem sensor. do you have any. i want to make sure it will connect to the harness i getting ......Andy i just ordered a 8 rib bracket from you today got some belt slip issues i trying to fix.
Old Nov 9, 2009 | 12:00 PM
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
I run a Dallas Performance card maf charge tube. It is as clean as any SD setup I have seen and I don't have to worry about temp / humididty issues.
Old Nov 9, 2009 | 02:02 PM
Fast06Z06's Avatar
Fast06Z06
You dont have to butcher the harness. You just cut the two wires you need for the IAT solder the two ends coming from the harness to the IAT and leave the other ones taped up and out of the way. If you ever need to put it back you just unsolder those wires and resolder them to the original two wires in the harness.
Old Nov 9, 2009 | 05:00 PM
Taylor@DallasPerformance's Avatar
0Taylor@DallasPerformance
Former Vendor
You can also pull the pins from the MAF connector if you want. Then pop those pins into the new IAT pigtail...
Old Nov 9, 2009 | 06:09 PM
Mr.Big's Avatar
Mr.Big
what Taylor said...
Dallas Performance MAF system here as well
To iat break out
