C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
NXL for LS3
Old Nov 19, 2009 | 07:52 PM
Dan Wendling's Avatar
Dan Wendling
Default NXL for LS3
Search the NX site but cant figure out if there is a Nitrous Express NXL System with integrated solenoid for an LS3 application?
Old Nov 20, 2009 | 12:22 AM
adam205348's Avatar
adam205348
Someone else can chime in but I do believe that their LS1/LS6 system will work on any LS style motor including the LS3. Their nozzles go into the intake where your fuel injectors go and then your fuel injectors go into the nozzles. I dont think there is a difference in injector size as far as the part that goes into the intake is concerned for any LS motor. They might provide the way, but you will need to be able to raise and mount your fuel rails and injectors up higher with spacers or something.
Old Nov 21, 2009 | 01:18 AM
Nitro Dave's Avatar
Nitro Dave
The NXL system would not work with the LS2 due to the solenoids going inwards and hitting on the intake manifold. I would be willing to bet the LS3 is the same way. If you are spraying enough to need a directport I would suggest using a real directport over a under the injectyor style nozzle anyways.
Dave
To NXL for LS3
