C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Best meth kit?
Old Nov 28, 2009 | 03:39 PM
juicedz06's Avatar
juicedz06
Default Best meth kit?
About to install my A&A vortech YSI and looking at meth kits, not very familiar with water/meth. Been reading all day, looks like the ECS kit or probably the AIS system are best? Seems like people stay away from the snow kit?
I'll be running 10-12psi. I just don't want to base my tune on the alky and something go wrong with the alky kit
the ecs kit is pretty much set up already right? no need to adjust stuff on the pac box?
Old Nov 28, 2009 | 06:26 PM
Quiky One's Avatar
Quiky One
Go with the ECS alky. I run two of alkycontrols kits and love them. Going on 4 years without an issue!
Jason
Old Nov 28, 2009 | 07:04 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
instructions
http://www.eastcoastsupercharging.co...ac_install.pdf
Old Nov 28, 2009 | 07:14 PM
BADZ's Avatar
BADZ
Running a snow kit here with NO problems...
Running 100% meth!!!
Simple install...
Do a search as there is a lot of "meth kits" info...
Old Nov 28, 2009 | 07:15 PM
blackvette101's Avatar
blackvette101
does the ecs kit come with a failsafe in case the meth doesn't spray? And is pump capable of running 100% meth?
Old Nov 28, 2009 | 08:00 PM
Mr.Big's Avatar
Mr.Big
the Alkycontrol kit modified by Dallas Performance is the VERY best option out there imho... and 100% methanol compatible...
see link below
http://www.dallasperformance.com/DPC...Alky/index.htm
Old Nov 28, 2009 | 08:40 PM
Fast06Z06's Avatar
Fast06Z06
I personallly Love the CMGS kit. They are the only ones on the market with a 52 mm fully digital progressive gauge that controls all functions rather than alittle box with ***** In addition there pumps blow the competition out of the water. 250 psi pumps your not gonna run short with that I run the CMGS Stage 2 kit. Works flawlessly.
http://www.coolingmist.com/detailmain.aspx?pid=cmgs
Old Nov 28, 2009 | 08:43 PM
bosco 08's Avatar
bosco 08
i've been running a Snow Performance Kit with Safe Injection for over two years in my hot rod Subie [AVO 380 turbo@23 psi 325whp/340wtq] i run blue windshield washer fluid and it works great. the kit added 20 whp over the tune with no meth.
it's a daily driver and sees ALL weather conditions 24/7 and has never once failed me. good luck.
Old Nov 28, 2009 | 09:44 PM
Quiky One's Avatar
Quiky One
http://www.alkycontrol.com/
Then click on pumps. I think you will be pleasantly surprised with the precautions Julio takes.
Again, this is the ECS/dallas performance/alkycontrol. Same kit!!!
Old Nov 28, 2009 | 09:55 PM
juicedz06's Avatar
juicedz06
what about this one?
https://www.alcoholinjectionsystems....roducts_id=102
Old Nov 29, 2009 | 07:04 AM
Dan Wendling's Avatar
Dan Wendling
Default Experience with Coolingmist kit
The Coolingmist CMGS controller looks very nice on paper. Anybody other than Fast06Z06 with direct experience using this kit.
Most interested in experiences using the dual input injection mapping based on MAF / MAP, as well as the use of the Fail-safe relay control output.
Old Nov 29, 2009 | 09:39 AM
juicedz06's Avatar
juicedz06
Originally Posted by juicedz06
good old air fuel gauge is what my fail safe is going to be, think I am going with the alcohol injection systems one
Old Nov 29, 2009 | 09:45 AM
Mr.Big's Avatar
Mr.Big
I much prefer to tune with the FAR SUPERIOR "ecm" the car comes with... I want a very simple methanol control unit that ramps in, and sprays at the level I set it at. period... simple... the fueling, timing and fail safe systems are then controlled by tuning the ECM. The rate of monitoring and ability of the ECM are MUCH better suited for these tasks. This is what works, and the best solution for our platform for several reasons imho... don't buy into the hype, the ECM is where you want 99% of your tune for methanol injection to come from...
Old Nov 29, 2009 | 10:05 AM
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
....and should the system fail or you run out of methanol, the ECM can automatically compensate.
Old Nov 29, 2009 | 10:19 AM
juicedz06's Avatar
juicedz06
how are you doing this? hooking the system up to run off of the MAF signal instead of boost? sorry if this is stupid questions, I'm an old school ls1 guy getting back into the game and theres alot of goodies out there now!
Old Nov 29, 2009 | 11:06 AM
TRIZ's Avatar
TRIZ
Labonte kit is the best I know of.
I've installed the ECS / Alkycontrol kits (they're the same) and the Labonte on my own car.
Labonte kit is much harder to install than Julio's.
Labonte references the manifold pressure and the IDC to calculate injection volume and rate. Also has failsafe.
Labonte has actual meth flowrate feedback.
I think there's another good kit that's missing from the list.
Good luck!
http://www.labontemotorsports.com/store/index.php
Old Nov 29, 2009 | 12:44 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
We use AIS on all of our cars.
To Best meth kit?
Old Nov 29, 2009 | 02:00 PM
juicedz06's Avatar
juicedz06
you're doing my tune so I am ordering the AIS tomorrow!
SPORT ATV
Old Nov 29, 2009 | 07:55 PM
Fast06Z06's Avatar
Fast06Z06
No actually what you do is disable the MAF sensor in the ECM and remove from the car and use the two wires for the IAT of the 4 that are there and use for a 2 bar map sensor and install that in the intake pipe. Then you go through the tune and set it up for a Speed Density tune. Once the computer starts and sees no maf signal it automatically defaults to the SD mode.
Old Nov 29, 2009 | 10:16 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
The "fail safe" would be in the tuning, and yes the kit can run 100% meth. (as we recommend)
We are proud to be the first shop bringing meth injection to the Corvette community several years ago, and we are pleased to have had the most consistent winning results from the system we use ever since.
Many others have come into the market, but we have continued to set, and hold, records with the ECS/Alky control kit. Which was named so since we developed the kit specifically for the Corvette with Julio. (C5 at that time).
