C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Problem with A&A SC install
Old Dec 5, 2009 | 10:35 AM
Victor'sVette's Avatar
Victor'sVette
Default Problem with A&A SC install
I have an 08 Z51 that I am installing an A&A SC (I also purchased the dewit radiator).
The head unit and main bracket bolt on just fine, but when I clamp the 6" metal tubing to the SC outlet (as in the directions) and try to put the unit in, it will not line up because the metal tubing hits the ps cooler.
It appears that the 90 degree rubber elbow will need to pass between the sway bar and the ps cooler, but hit compresses the tubing.
Is there something that I am overlooking (it has happened in the past) and an easy solution?
If anyone has any advise, please let me know.
Thanks,
Victor W.
Old Dec 5, 2009 | 10:40 AM
Paratrooper307's Avatar
Paratrooper307
I don't know if this is true for the 08, but in the instructions it says to remove and bypass the power steering cooler.
Old Dec 5, 2009 | 10:51 AM
Fast06Z06's Avatar
Fast06Z06
yes thats exactly right. You need to bypass or get a smaller cooler and relocate. I took mine out.
Old Dec 5, 2009 | 10:54 AM
Victor'sVette
Ok, that makes sense. I didn't find it in the directions, but I can't see how to install the unit with it in the car. Thanks, I will go and remove it.
I appreciate the advise.
Victor
Old Dec 5, 2009 | 12:08 PM
Motorhead-47's Avatar
Motorhead-47
Page #10 Paragraph 2.5
"Remove the factory clamps from the power steering hose at the cooler inlet and outlet lines. The factory clamps are removed by inserting a small blade screwdriver into the opening and prying them open. Remove the cooler and splice the two hose ends
together with the supplied 3/8” barbed splice and clamps."
Old Dec 5, 2009 | 02:41 PM
Spying Beast's Avatar
Spying Beast
Same here.
Old Dec 5, 2009 | 03:44 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Me and Motorhead-47 have done two Z51 cars (mine included) and the PS cooler has got to go. My PS cooler now resides in Motorhead-47's 09 coupe.
Old Dec 5, 2009 | 04:07 PM
drivinfast's Avatar
drivinfast
I suggest relocating the cooler somewhere where air can pass thru it to allow the little bit of cooling it allows to the PS pump. I had to replace the pump $350.
Old Dec 5, 2009 | 06:46 PM
Victor'sVette
MotorHead, your right, I did miss it. Like I said, somethimes I over look the simple Sh*t.
I think that I will take drivinfast recommendations and look for a smaller cooler to relocate. Thank you, everyone.
This is why I joined this site, great advise, very quickly, from people that have done everything that I might think about doing to my car, which is the best corvette I have every owned!
Victor
Old Dec 6, 2009 | 07:32 AM
Fast06Z06's Avatar
Fast06Z06
Depends on your goals with the car. If you are planning on Road Coursing or Auto X then yea get a small one atleast. If not no reason too it wont over heat from normal driving or even a small spirited run.
Old Dec 6, 2009 | 12:55 PM
Boat Racer's Avatar
Boat Racer
Default Power Steering cooler?
Dumb question but do all C6's have a PS cooler or is it only the Z51 optioned cars?
Old Dec 6, 2009 | 01:23 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
I used a base C5 PS cooler on my C6Z06 when I did my supercharger install. The base C5 cooler is just a tube and bolted in the same place but allowed room for the charge pipe.
Old Dec 6, 2009 | 02:55 PM
Motorhead-47
Part of the Z51 option package...not on base or F55 cars.
Old Dec 6, 2009 | 02:57 PM
Motorhead-47
My F55 equipped C6 had the same "tube" in lieu of a cooler.
Old Dec 6, 2009 | 03:43 PM
excessive81's Avatar
excessive81
i made new braket for mine to lay it horizontal of the front of the k member
Old Dec 6, 2009 | 08:18 PM
Victor'sVette
excessive 81, please attach a photo if possible. thanks
Old Dec 6, 2009 | 08:55 PM
zer0t's Avatar
zer0t
St. Jude Donor '08-'10
How hard was it to "pin" the crank?
Anyone near by who wants to supervise or help--I'll provide all the beer and pizza they want. ;-)
To Problem with A&A SC install
Old Dec 6, 2009 | 09:25 PM
Motorhead-47
Pinning the crank with the supplied fixture is a no-brainer...be sure to use a fresh quality 1/4" bit. Getting to the crank to pin it is the fun part!
Old Dec 7, 2009 | 12:25 AM
Victor'sVette
Like above, pinning the crank is very easy with the collar supplied with the kit. I personally used electrical tape on the bit to cue me when to stop drilling and kept stopping to measure way too many times.
Again, as above, there is a couple little things you have to remove: sway bar, radiator, ps cooler (my nemesis by not reading the directions), loosen the ABS and remove the steering rack.
I personally removed the alt and ps pump, although I can see (now) that it may not be necessary for this job. I also removed the hood for ease of looking at everything (when I did the cam swap, I left it on, but it was a lot easier without it on).
The only thing I really had a problem with was the ac condenser, for me it didn't want to separate from the radiator very easily. And it was even more fun to put back the first time but 1000% easier without the hood in place...or maybe doing it twice.
Bottom line, pinning the crank was very easy, getting to it took a couple hours and a little swearing. If you pull the ps pump, plan on spending about 10 long minutes working on getting three bolts out, a quarter turn at a time, but not a hard task.
Old Dec 7, 2009 | 07:02 AM
zer0t's Avatar
zer0t
Thanks for the detail it helps me decide whether or not I want to take on the task. I see the A&A kit is on sale for 4875.
