C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Home Made Drag Wheel Setup
Old Jan 16, 2010 | 12:34 PM
  #41
STROKD's Avatar
STROKD
Originally Posted by jimish
Can you tell me the width and offset of the GTO wheels as compared to 17" front C5 wheels?
I am thinking of narrowing a set of 17" wheels to 4-5" and using motorcycle tires on the front.
GTO spares are 17x4". DONT run motorcycle tires, I thought the same, BUT they are rounded on teh edge and will handle terrible imo...
If you want radials, get the MH Racemaster 185x55x17s... They are 26" tall and speed rated to 250 mph according to John at MH. Should have you covered for the speed rating.
This is the BIAS PLY tire the OP has... you can run these with radials in the back but its not recommended...
http://www.mandhtires.com/store.php?...on=show_detail
This is the RADIAL version of the same tire above, which is what I am currently using... Its about 5 lbs a piece heavier than the Bias Ply but more stable... The radial is not recommended AT ALL if you run a Bias ply in the back... basically run the same type tire front and back and it will be better... mis matching makes the suspension fight and the car walks around a LOT.
Old Jan 16, 2010 | 10:29 PM
  #42
PartsTaxi.com's Avatar
0PartsTaxi.com
Former Vendor
Originally Posted by STROKD
call Kevin at Parts Taxi, he had em last month for like 137 shipped... I got mine off a guy on here, or that was the way I was going to go for sure... I checked EVERYWHERE, Kevin was the cheapest.
Thanks for the referal!!! I can still do that for the pair shipped for anyone that's interested. I just checked stock and their are plenty still available.
Kevin
www.PartsTaxi.com
Old Jan 20, 2010 | 09:49 AM
  #43
Rob G's Avatar
Rob G
Default ?? on gto skinnies
Will they go on whit out the spacer will the stock lug nuts work,If not what size studs?
Old Jan 20, 2010 | 10:55 AM
  #44
MachineWorks's Avatar
MachineWorks
The liugs are fine. On a NON Z51 or a ZO6, these will not fit without a adapter. But, you will have to make the hole in the center of the wheel a little bigger.
Old Jan 21, 2010 | 11:23 AM
  #45
STROKD's Avatar
STROKD
almost... on a Z51 or Z06, spacers (or adapters) are needed to clear the calipers... on a base car such as mine, they fit without any spacers...
Old Jan 21, 2010 | 06:39 PM
  #46
Rob G's Avatar
Rob G
Know one would tell how big of a spacer for zo6 i had rodger from horsepower make me a set they were 1.5" wide they did not fit looks like 3.1/4" is the width needed to clear caliper.All made out of billet hope this helps some body.
Old Jun 6, 2010 | 04:27 AM
  #47
Insom's Avatar
Insom
I am suprised no one has asked how much weight savings?
Old Jun 7, 2010 | 03:10 AM
  #48
MachineWorks
Never weighed them? But, they are way lighter than my Iforged wheels.
Old Jun 7, 2010 | 09:17 AM
  #49
TurboVic's Avatar
TurboVic
Fronts: GTO spare with M&H skinnie = 25LBS
Rears: C5 Wagon wheel with MT's bias ply = 40LBS
Old Jul 7, 2010 | 09:26 AM
  #50
FRDnemesis's Avatar
FRDnemesis
Spare RIM, NOT the tires. They have Race Master tires on them. You can only go 55mph on the spare tires. These are only $70 each new from GM.
I'm guessing the spacers were more expensive than the wheels. What do you have in rims and spacers collectively? I'm weighing my options on trimming some weight this way vs. having a set of factory Z06 wheels narrowed.
thanks,
jeff
Old Jul 7, 2010 | 12:07 PM
  #51
396375's Avatar
396375
St. Jude Donor '08-'09
thanks,
jeff
I would narrow the Z06 wheels.Jusy my .02 but I think the GTO spares look like sh*t and even worse with rear rims painted black.On a Mustang sure.On a Vette no way.
Old Jul 7, 2010 | 01:13 PM
  #52
MachineWorks
Maybe you should keep your .02 cents to yourself...
Old Jul 7, 2010 | 03:23 PM
  #53
TT Vette Vert's Avatar
TT Vette Vert
Did the spares come black or did you paint them?
Old Jul 7, 2010 | 04:29 PM
  #54
MachineWorks
They come black.
Old Sep 17, 2010 | 06:37 AM
  #55
Joe_G's Avatar
Joe_G
St. Jude Donor '08
They are custom made adapters with ARP studds, lets just they are big.
Great thread. I've got the gto spares, GS widebody kit and am going to go with Z06 brakes. I don't want to swap brakes back and forth.
Where did you get the spacers and how much were they?
Old Sep 17, 2010 | 06:39 AM
  #56
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Is this Roger from HP sales Pompano? Did you ever get spacers to work, and did Roger make them?
Old Sep 17, 2010 | 11:32 AM
  #57
MachineWorks
BVI Machine made them for me. PM for info if you want.
To Home Made Drag Wheel Setup
Old Sep 17, 2010 | 01:37 PM
  #58
FNBADAZ06's Avatar
FNBADAZ06
I didn't think that wheel adapter's of any type passed tech at the strip ?
They allow small wheel spacers to a degree but that's it.
I'm checking into having a set of 18x9.5's narrowed down to 4", and what the cost will be.
Old Sep 17, 2010 | 03:54 PM
  #59
cencalc6's Avatar
cencalc6
how wide are the spacers?
Old Mar 7, 2011 | 07:22 PM
  #60
Joe_G's Avatar
Joe_G
St. Jude Donor '08
3.5". My friend Tkr has them...wow they are some big adapters, but he has no trouble with them.
Here's a thread with a link to ordering info.
Also, I didn't know this but per this thread apparently the CTS 18" spare fits z51 and z06 without spacers.
http://forums.corvetteforum.com/c6-z...-skinnies.html
