Please explain to me boost
QUESTION;
I would like to add a bit more HP and thinking about a cam. (should have done it while having the sc installed) but can I get another 40 rwhp by dropping down to a smaller pulley? what are the cons of doing this. Everything on the motor and transmission is stock.
THANKS, SLAMMER2
QUESTION;
THANKS, SLAMMER2
pros:
-cheaper and easier
-maybe take an hour to install
cons:
-could lead to belt slip if you go too small and are on the stock 6 rib setup
-we dont know the actual boost limitation of our motors, usually 8-12 is the max you can run
-more boost will create more heat, however your using meth so you are ok here
-more boost require higher octane but again you have meth for this
blower cam
Pros:
-increased power without any additional boost, basically makes your engine a more efficient air pump, you will actually see a 2psi loss of boost and make about 50rwhp more
-the sound if you like it
cons:
-cost, a good kit with springs, pushrods, and retainers will cost around 1k in parts and another 500-1000 in labor
-involved install, about 8 hours start to finish
-the sound if you want something that sounds completely stock
-if it is a big cam you could see some drivability issues below 2k rpm
honest opinion,
i would increase boost by 2psi and make your additional 40rwhp, however contact some shops and see if you can get a good deal at blower cam + install
I email A & A Corvettes this weekend see below and Andy responded this morning.
STEVE OR ANDY,
you did an install for me two years ago this october. wish I would have as
the installer more questions when he asked me if I was getting a cam. Fast
forward to today and I'm looking for that finial push to 600 rwhp I'm at 555
now. Can I install an 3.6 pully and get there I have 6 rib and the max boost
is 8.9 currently I have headers and running 100% meth with an alky control
kit.
Can I stay with the 6 rib and run 11 or 12 lbs of boost. what about belt
slip?
I'm told that with stock internals I don't want to exceed the 600 rwhp mark.
I have an auto trans as well on my 2006 c6. What additional information is
needed for you to give me good results along with watching my budget as
well. can I go to just a smaller pulley or will I need the 8 rib kit as
well. or have fi cam installed. these last 45 hp can be expensive! I
already upgraded my dongle and larger filter last month.
Thanks for taking the time to help me make a educated decision.
Tim
I'd go with a small blower cam and a smaller pulley.
That should do it for you. 6 rib should be fine.
Thanks, Andy Green
A&A Corvette Performance
477 Lambert St
Oxnard, CA 93036
thanks,
slammer2
