C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
DeWitt's Radiator
Old Feb 23, 2010 | 08:10 PM
Robls6's Avatar
Robls6
Default DeWitt's Radiator
I am thinking about upgrading the radiator in my 07 6 speed manual non Z51 A&A vette. The car right now doesn't really get over 220 in really warm weather but the fans need to run almost constantly. I really don't like relying on the fans to cool the car plus they sound horrible too. What do you think a standard radiator (no internal coolers) will do? Will it keep the car under 200 degrees without much use of the fans? I also want a little more clearance between the blower intake and the top of the radiator too so the installation looks a little better.
Old Feb 23, 2010 | 09:03 PM
knkali's Avatar
knkali
here you go
http://forums.corvetteforum.com/c6-f...ns-cooler.html
I agree with the fan noise being bothersome
Old Feb 23, 2010 | 09:51 PM
bullitt4110's Avatar
bullitt4110
Check out the RSD radiators, very nice units that work.
Old Feb 23, 2010 | 10:21 PM
wooden's Avatar
wooden
regardless which radiator you go with the fans will have to run to keep it cool, I am running a dewitts with dual fans, around town the fans run constantly
Old Feb 23, 2010 | 10:26 PM
BADZ's Avatar
BADZ
Some guy's say stay with stock to get more air up thru the extra space but I went with a Dewitts to try it out, there was not much difference in temps. Wooden is correct on the fans running constantly in the hot summer time...
Old Feb 24, 2010 | 08:22 AM
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
I added a EWP. It lowered my temps by 10-15 degrees around town driving.
Old Feb 24, 2010 | 03:06 PM
Robls6's Avatar
Robls6
I'm not a big fan of electric water pumps on street cars. I just ordered the Dewitts so we will see what happens. At the least it will make the installation look a little better. I was definitely not a fan of cutting the stock radiator and folding over the flange on the top to make the intake fit into the blower.
Old Feb 24, 2010 | 03:18 PM
Taylor@DallasPerformance's Avatar
0Taylor@DallasPerformance
Former Vendor
Just like almost everything else on the LS engines, these are different. Don't compare to old school SBC stuff. The EWP's work perfectly fine on the LS engines on street cars. I have never seen one fail. And they make zero noise.
Main benefit is that you get FULL FLOW at idle. Not progressive flow with RPM like mechanical pumps.
Old Feb 24, 2010 | 07:29 PM
Robls6's Avatar
Robls6
I see your point, but it's not really "progressive flow". The mechanical pump impeller is designed to flow over 85% of it's designed flow right off idle so I really dont see the need to spend $1500 or more on an electrical pump on the street.
Old Feb 24, 2010 | 08:06 PM
EuroRod's Avatar
EuroRod
I run a Ron Davis radiator, 160 t'stat, stock fans and a big oil cooler on my ProCharged 2005. I also use the Meziere EWP. It flows a constant 55 gph, the stock pump pushes 22 gph @ 5000 rpm. In summer heat, ac @ 100%, I see coolant temps around 190, and oil temps around 200. Thats at highway speeds. Around town, the temps run 10 to 15 degrees less. I can sit in traffic when it's 110 outside and never overheat.
Old Feb 24, 2010 | 08:38 PM
Former Vendor
Electric water pumps are around $650.
Old Feb 24, 2010 | 09:14 PM
knkali's Avatar
knkali
Are you sure on the around town figs? Seems it would be the other way around. IOW in traffic less air flow through the radiator would up the temps. BTW where did you mount the oil cooler with the IC up front?
Old Feb 24, 2010 | 10:51 PM
Jorday's Avatar
Jorday
Agree on both. I used a EWP for a long time in a daily driver never had an issue, and the increased flow at idle and even in the lower RPM range definitely helps.
Taylor is right the cars do run cooler if you can flow more water than the stock pump at any engine speed under 2000 rpm.
Take a stock Z06 and put a 160 thermostat in it and cruise down the highway at 70 mph it will run 180 something. Then, keep going 70 but downshift to 5th to speed up the stock water pump a little bit and the engine temp will drop lower than it will ever reach if you leave it in 6th.
The ZR1 is the same way. I use that trick all the time to get as much heat out of my engine as I can before I run someone from a roll, on a closed track of course.
Old Feb 25, 2010 | 09:52 PM
EuroRod's Avatar
EuroRod
In traffic, the engine does not generate as much heat energy as when it's working hard at speed, and my cooling system so eficient that I do experience lower coolant and oil temps at slow speeds.
To DeWitt's Radiator
