C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Fuel System Help
Old Mar 25, 2010 | 03:42 AM
Bad News's Avatar
Bad News
Default Fuel System Help
Im trying to plan out a fuel system for my my 600rwhp build. I was originally planning on a duel in talk Walbro 255 setup and not using the Magnavolt BAP that came with the supercharger kit. However I went a little over budget on my build and I don't really have the money for it if it is not absolutely necessary. My question is should I still upgrade the stock pump to a single Walbro 255 and use the Magnavolt BAP along with it? Can the Magnavolt handle the new bigger 255 pump? Or should I just stick with the stock pump and the BAP?
Old Mar 25, 2010 | 09:29 AM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
The stock pump and BAP should be fine for that power level.
Old Mar 25, 2010 | 05:14 PM
Bad News's Avatar
Bad News
Would I benefit from swapping it out for the Walbro if I plan on dropping the tanks anyway?
Old Mar 25, 2010 | 05:17 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
The stock pump and BAP has proven to be good at that level but if you're planning on dropping the tanks anyway then do twin Walbros. Either that or a Z06 bucket. But I wouldn't drop the drivetrain and tanks just to do this alone, do a clutch at the same time.
Old Mar 25, 2010 | 06:26 PM
Bad News's Avatar
Bad News
It would be easy for me to drop the tanks because I already have the rear cradle out for a diff swap. In the long run I do plan on doing twin Walbros, Im going to do one in each tank actually, however at this point I don't really have the budget for it. My question is should I go ahead and swap out the factory pump for a Walbro 255 and more importantly can the Magnavolt handle the Wablro?
Old Mar 26, 2010 | 02:18 AM
Bad News's Avatar
Bad News
Ttt
Old Mar 26, 2010 | 02:43 AM
MachineWorks's Avatar
MachineWorks
Sorry to put it like this. If the $220 for two pumps is breaking the budget. Get a cheaper hobby. You realy don't want to short yourself on the fuel side of a build. You should be fine at 600 with a BAP, Racetronics fuel pump hairness and the stock pump.
Old Mar 26, 2010 | 02:57 AM
Bad News's Avatar
Bad News
$220 is not breaking my budget. If I did a twin Walbro setup I would put one in each tank and run a return style system. After the pumps, regulator, fittings, and fuel line I would be another $650 into it. Trust me I know this is not a cheep hobby. Im already $14k into my build and trying to wrap it up. I plan on going to the twin Walbro setup later down the road. Should I go ahead and replace the stock pump with a Walbro now and supplement it with the bap? That way I have at least one of the pumps out of the way. Or should I just leave it alone and run the stock pump with BAP and do it all later? I know fueling is one of the most important things and I don't want to skimp on it. That is why I am trying to get as much input as possible.
Old Mar 26, 2010 | 03:18 AM
MachineWorks
You don't need a return line. Just y the pumps together, ect.....
Old Mar 26, 2010 | 03:23 AM
Bad News's Avatar
Bad News
So just put a walbro 255 in each tank and tie them into the stock fuel line? Would I scratch the BAP then?
Old Mar 26, 2010 | 09:10 AM
5 Liter Eater
St. Jude Donor '11
The other tank is just used for extra capacity and to balance the weight of the fuel. The pump in the passenger tank is just to send fuel back over to the drivers side tank for balance purposes. Billy (MachineWorks) and his partner have pioneered the twin Walbros in the stock bucket in the drivers side tank. The drivers side is where all the work is done. IMO replacing the stock pump with a single Walbro is not worth the effort. Two Walbros and the associated submersible fuel hose, connectors and such total well under $250.
Old Mar 26, 2010 | 01:15 PM
Bad News's Avatar
Bad News
Ok so two Walbros it is. Which 255 are you using? I believe there is a high pressure version and a regular version. Isn't that a lot of fuel to push on a return-less system?
Old Mar 27, 2010 | 12:51 AM
5 Liter Eater
St. Jude Donor '11
GSS340, 341 or 342 is what you want. Preferrably the 340 due to the larger inlet.
Old Mar 27, 2010 | 01:03 AM
Bad News's Avatar
Bad News
Sent you a PM also.
Old Mar 29, 2010 | 02:04 PM
Isaiah48's Avatar
Isaiah48
I like the idea of the ease of just putting twin 255's in the one tank, but what about the excessive heat from constanly running 2 pumps full time, even when at idle and low speeds. I'm not sure just how much heat a system like that would generate, but it has to have at least some negative heating affect. My 928s actually runs the fuel through the ac system to try combat heat. Is there anyway to run the second pump off some type of demand sensor? I guess then the problem would be running a new set of wires into the tank for the second pump without the fuel wicking back up the wire, causing a possible leak...
Maybe I'm over thinking this whole thing...
Old Mar 29, 2010 | 04:35 PM
5 Liter Eater
St. Jude Donor '11
Here is a CF thread with links to LS1Tech and other sites with various dual pump pics and writeups. Lots of the F-Body guys wire the second pump into a hobbs switch to only start pumping under boost. For your purposes you could use a window switch.
http://forums.corvetteforum.com/c6-f...uel-pumps.html
you would have to drill a hole in the hop of the fuel pump hanger to run some more wires and then seal it up with your goop of choice. The C5 fuel tanks have the hole for the hanger/bucket at the top unlike the C5's so I don't think there is much cause for concern about a leak there.
To Fuel System Help
