Spec Twin clutch question
Apr 1, 2010 | 11:54 PM
For those that have it or tuners who install them, do you use the included shim for the slave?
Apr 2, 2010 | 01:34 AM
Spin, YES! You absolutely have to use this!!!
Apr 2, 2010 | 09:42 AM
Yes, it should be included if your going twin disk.
Mine feels perfect like stock since break in period. It laughs at 860 tq.
Jp
Apr 2, 2010 | 09:49 AM
And what a beautiful sound that laughter is!
Apr 2, 2010 | 07:36 PM
Spec twin original did not require a shim. The clutch was revised about two years ago and the stack height was changed and it now requires the use of a shim. Call Spec directly and speak with Jeremy for conformation.
Apr 2, 2010 | 09:57 PM
depends on which one you have you may or may not require the shim. i have spec twin in mine and love it( no shim by the way). Also jeremy is the person to call in regaurds to which is what
Apr 2, 2010 | 10:05 PM
Jeremy is sharp as a tac! No doubt! But so is everyone else there (Gary Lang, Matt, etc...)
Any spec twin made in the last 2.5 years will require the shim. Period.
Apr 3, 2010 | 05:30 AM
I bought mine about 10 months ago and it came with the shim. I have bought clutches before that came with a shim but it was only for guys installing it in an F-body.
I'll use it.
Apr 3, 2010 | 12:05 PM
Good idea!!!
Quote:
Originally Posted by
SpinMonster
I'll use it.
Apr 3, 2010 | 12:23 PM
BADZ
Jp
it laughs at the idea of being streetable too.
Apr 3, 2010 | 12:36 PM
Jorday
My super twin took a couple of thousand miles but finally the chatter/shudder has basically disappeared but has a high pedal engagement. When new it does take a while to get used to.
Apr 3, 2010 | 02:40 PM
True statement but after the breakin, my clutch is smooth as butter now...
Jorday
Apr 3, 2010 | 02:50 PM
which version do you guys have just out of curiosity?
Apr 3, 2010 | 02:58 PM
Jorday
Spec Super Twin Carbon.
Apr 3, 2010 | 03:17 PM
what one is that the ST trim?
Apr 3, 2010 | 04:08 PM
Jorday
Mine is not ST, it does not have a designation. On the Spec website it's under the multi disc section.
Apr 3, 2010 | 04:13 PM
I have the PT trim disks. Mine are now carbon/carbon also.
I did have the SS organic disks but swapped them out since I raised the power and knew it would only hold temporary.
The full metallic is the disk for track use only and not very streetable from what I did research on.
The ST is one step above mine but I'm sure comes with the metallic disk.
Apr 3, 2010 | 04:24 PM
IDK which one you have then saplumr
BADZ
I had the ST and it was not too friendly.
