C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
boost? 402 D1
Old Apr 3, 2010 | 09:27 PM
a/c man's Avatar
a/c man
Default boost? 402 D1
how much boost can a D1 put out for a LS2 402! mine seems low! 12-14lbs with a 3.40 pulley stock crank pulley! anyone know
Old Apr 4, 2010 | 08:33 AM
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
The amount of boost a car makes is dependant upon a lot if things, e.g., cam, heads, displacement, etc. The better question is how much power are you making? If you want to make more, go with a smaller head unit pulley. There is a really good deal from someone selling a Flip Drive, which will help prevent slippage when you turn up the boost.
Old Apr 4, 2010 | 11:10 AM
BADZ's Avatar
BADZ
An 8 rib setup would be just fine on a D1 spinning it to the moon w/o the flip...
Like aTX said, there is alot of factors in order to figure boost..
Old Apr 4, 2010 | 11:36 AM
a/c man's Avatar
a/c man
I'm scared of the flip drive Ive heard bad stories like squeals and bearings going out!also looks like a pain in the a$$ to install! but i bet I'm slipping the belt it should see more boost!
Old Apr 4, 2010 | 12:40 PM
excessive81's Avatar
excessive81
that is about what i ran (12psi)when i was running a 3.5 pulley. but i would be SHOCKED if you are not getting belt slip...
Old Apr 4, 2010 | 01:09 PM
a/c man's Avatar
a/c man
thanks this is helpfull did you have a 402 D1 give me details please!
Old Apr 5, 2010 | 10:42 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Upgrade to an 8 Rib setup and keep your 3.4 pulley to see the end results, I did not do a IC Overdrive Balancer, if I did I would see more boost than I do now on my little 347. I have zero slip with Andy's new bracket and 8 rib setup, recently certified his setup at the Texas Mile where I saw 20# in 4th gear and 16# in 5th going through the traps at 6000 rpm and a mere 190 MPH
Old Apr 5, 2010 | 12:45 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
No issues with peter pan's and he runs the crap out of it.
Old Apr 5, 2010 | 01:30 PM
MachineWorks's Avatar
MachineWorks
Mine makes 19 to 20psi 8.25 lower and 3.4 blower pulley. Its going to run out of air. I would put a F1 on it.
Old Apr 5, 2010 | 01:52 PM
aTX427's Avatar
aTX427
You hear the same issues with belts from installing blowers. If you do it correctly, you will not have issues. If you don't, forgetaboutit.
Old Apr 5, 2010 | 01:58 PM
a/c man's Avatar
a/c man
i just found my crank bolt came loose!!!!!!!!!!!!!!!!!!
Old Apr 5, 2010 | 02:12 PM
bullitt4110's Avatar
bullitt4110
You should just buy my flip drive
Old Apr 5, 2010 | 02:21 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Wow, that is not a good thing, great find before you had a real boom
Old Apr 5, 2010 | 02:22 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Did you pin the crank? With it pinned it should not of come loose, even if torqued incorrectly.
Old Apr 5, 2010 | 02:59 PM
a/c man's Avatar
a/c man
yea it was pinned!!! I'm scared to look at the damage it may have caused oil went all over my belt and when i checked the bolt it had some metal dust around it like it slipped on the crank
To boost? 402 D1
