.::NEW House of Boost/Aeromotive Fuel System::.
#101
Former Vendor
We've done several and the "over-heating" is indeed a non-issue. It doesn't stop the haters from posting otherwise as that's what they do....but facts are, there is no heat issue.
AEROMOTIVE IN-TANK RESULTS
This is a very common misconception about pumps overheating. The A1000 is the size of two 255's. So it moves a large volume of fuel. Fuel flows through the pump, so if the pump is hot what does that tell you about the fuel? Now where the heat comes from. The fuel is pumped through a fuel rail (heat sink) attached to a hot engine enclosed in a hot engine bay. The fuel is then returned to the fuel tank. The longer you drive the hotter the fuel gets. Not only because of time but the amount of fuel in the tank keeps getting lower.
As long as the pumps are installed with the right wiring and filters you will not have any issues. For those concerned with heating issues you can install a 16306 speed pump controller. It reduces voltage (pulse modulates) to the pump to make it run slower and is RPM activated. Hope this helps guy!
#102
#103
What about running a fuel cooler on the return line to combat the gradual increase of the in-tank fuel temperatures.
Recirculating warm fuel only results in one thing: warmer fuel. Keep this process going for 4 hrs straight (ie: highway trips) coupled with a decreasing level of fuel in the tanks and what do you get??
Both the A1000 and Elminator are awesome pumps, but won't they both eventually get very warm thus risking injury to the pump, even with the speed controller??
#104
good question and wondering about the answer from Aeromotive..
Do you installed A1000 or the eliminators pumps ?
I having heating issues and vapor lock from the Eliminator pump, I bought the HOB c6 complete system.
Also many other members reported that have same heating issues with A1000 and Eliminator in-tank pumps..
http://forums.corvetteforum.com/c6-f...or-pump-3.html
#106
Like what? The only thing mine didn't include was a fuel pressure gauge (but that's because a user can choose what to use) and a tach driver, but the tach driver isn't even needed.
#107
I wouldn't say it makes the kit, or in this case, the in-tank engineered piece garbage? Perhaps not getting all the fittings is "garbage" but as far as the pump assembly goes, its far from a POS...
#108
At least in his car there IS a heat issue!!!!
#110
I have no experience of the complete kit. I bought the Eliminator version of the pump + the controller and built the rest myself.
Heat is always a issue with a fuelsystem having the regulator + return line going from the engine compartment. I have the regulator just beside the throttelbody and I have all the lines heat insulated and routed as far away from exhaust side as possible. That include the lines to/from the tank.
#111
Zero heat issues here. Maybe it have something to do with how the rest of the system is designed
How many hours did you drive your car withot any stop; truning off the engine?
Outside and your coolant temprature?
Do you have heat extractors hood?
It seems that these are major factors to get the overheating suituation!
For normal driving, at least for me, less than 30 minute,,, it was ok
even tuning the car on the dyno and taking 5 - 6 runs or more,,, no problem at all
but anything else,,, you will be on side of the road to cool down the damn fuel system! and you cannot drive the car for longer period anymore,,, otherwise the overheating suitation and pressure drops everytime,,, the more time you cool it down,, the more you will you be able to drive it!! of course you will not exceed the 30 minute period!
#112
What is the return line used -8AN or -6AN ?
#115
#116
I have the eliminator pump and stopped my build for other reasons. But now I am sitting on a lot of brand new parts and one of them is this complete eliminator fuel system with controller, lines , gauge, ect.
I have $ 2,500.00 Into this stuff and feel like I am stuck with it. Any suggestions ? Some seem to be ok with them and some not. I would hate to sell this thing to someone and them be pissed at me. Will Aeromotive take it back ? Most companies do not return electrical parts, I would be happy with a credit if they stand behind their products. I hate to sit on this stuff, I want to move on with my new build.
http://forums.corvetteforum.com/c6-p...te-system.html
#117
Why would they take a product back that you have had no issues with and just no longer need?
#118
I am not bashing Aeramotive and know that the majority of companies will not return electrical parts period. I have used their stuff in a couple of my cars and never had issues. But it seems as though their are people in here that are having some issues with them and people that are standing behind them with good results. Just trying to sell the system at this point, I do not expect them to take it back. I am buying an eliminator pump that is set up for a Cobra jet fuel tank and at first thought I could just use the one I have, Aeramotive advised me to sell the kit because they are " selling like hotcakes " instead of them trying to take this one apart and set it up for what I need it for. I agree with them, it makes more sense to start with the right one. I am not sure I feel comfortable selling it to someone and then them coming back at me because whatever reason. That is what I was looking for some insight on.
#119
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,830 Likes
2015 C7 of the Year Finalist
caveat emptor. Don't make any promises, just list it exactly for what it is. If there is an issue, it can't be blamed directly on you if in fact you have never installed or used the device. You're selling it as "used" with no guarantees on your part.
Elmer
#120
