Are you commanding 3.5deg of timing? Something is wrong. Your timing is all over the place.. 3.5deg of total timing won't burn a damn thing... and your wideband is showing the overall AFR of the car. When you have rich unburnt fuel, it will sometimes read dead lean. When people say start low with timing doesn't mean start at 0!
Generally, something in the low teens (12-14deg) is a safe bet to start. Do a street 3rd gear pull to make sure you get no KR. Adjust AFR. When AFR is dead on play with the timing and make minor AFR adjustments along the way.
Trapping 104 I'm assuming your car has a blower on it.
I don't see any wheel hop. Your mph didn't spike up.It stayed at a steady rate of climb as well as your rpm. You didn't get knock from wheel hop. . In your case not enough timing.
the reason the timing is soo low right there is because the IAT's and the IAT table is taking away lots of timing. previous run with spot on fuel only had 6 degrees of timing.
thanks, but i figured out the problem, heat soaked
i was popping the hood, only unlatching it, and all the heat from the motor was going past the hobbs switch, which overheated it,
going to goto a twin 255 tank setup since the A1000 wont be out until fall i think
