Thanks alot guys. Tiago did a badass job. Hopefully we'll get some break in mile this week if the weather coops. The wheel and tire setup are CCW 18X13 with 345 Mickeys
Originally Posted by 427silverhotrod
Very nice looks great when you going to dyno it and what wheels/tire size type you running.
Great build . Do you have any ground clearance issues with pipes going under frame? Know it's a compromise on a C6.
Mike
It is no lower than the front cross member is, I don't expect ground clearance issues other than the normal... my viper is 2" off the ground and it gets around, just got to drive wisely Thanks!
Originally Posted by PCMusicGuy
Tiago, have you been designing intercoolers at work instead of skids?
Looks like top notch work. Have any pictures inside the wheel wells with the liner back in?
this is my moonlighting operation weekends only
I haven't reinstalled the wheel wells yet, waiting to put some brake in miles on it first and check everything over before doing that. Thanks!
Originally Posted by old motorhead
That's got to be one fabricating ****. Stuffing all that in, under, and around a C6 engine bay is amazing and has got to include a little magic. Kind of like 16 clowns crawling out of a volkswagon. Props to you guys!
thanks!
Originally Posted by Mr.Big
I got to see this beast in person, when Tiago allowed me to store my car at his shop during Tx2K10, Can't Thank him enough for his kindness... As for this car... everyone better watch out!!!
Hey Jeremy, hows the car? Make it back to Dallas ok?
mickey thompson 345 18" DR hopefully will be on the dyno in a couple of weeks.
Originally Posted by wannagofast
Wow There is a few hundred hours of fabricating!!! Nice work guys
yea definately a few hundred hrs
I need a vacation
Originally Posted by EdwardETraylorIII
Tiago,
I believe you're the gentleman I met in Orlando about 2 years ago!
That's one heck of a build! I believe those turbos are just big enough to make some serious power! Great job!
not at all worried about engine heat in that spot...
What are your IATs, and have you hung a thermistor near the intake filter(s) to see what temps they are sucking and how they compare to ambient?
I think it is a concern @ speed unless you have a hood designed with heat-extraction louvers, as this is exactly the path (unless I am grossly mistaken here) that underhood air goes after that fat intercooler & radiator you have (+ around the bell housing, but that's not a concern).
the hood does have heat extracting vents in it. The turbos will be getting fresh air from the wheel wells more than engine heat imo in that spot, we will just have to see the IAT's when we get some miles on it.
we had a problem with the stock fuel pump and we had to go back into the gas tank and fix it, its a major pita with the rear/trans on the car
Also working on putting a higher output alternator on it, because we were draining the battery when the big fuel pump is running.
this weekend should get some seat time for sure though
Awesome build Tiago, I am pretty sure I met you down at the mile in october last year. I actually have a TT kit for my C6 that is very similar to this setup. I can't wait to finally get it up and running. Would you mind if I pick you brain about a couple of small things?
