C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
crank pulley
Old May 4, 2010 | 11:11 AM
DEODELTA's Avatar
DEODELTA
Default crank pulley
After installing a Maggie 122 my balancer on the crank got tweaked so I'm looking to replace the pulley with a more stout option. ...you guys have one that you have used that you Can recommend over stock?
Old May 4, 2010 | 11:15 AM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
http://www.eastcoastsupercharging.co..._balancer.html
They are available in standard diameter as well as overdrive if you want to up the boost a bit while youre there.
Old May 4, 2010 | 07:02 PM
Bad News's Avatar
Bad News
I'm in the same shoes as you. After my TVS 2300 install my balancer seemed off. I ordered the 10% overdrive one above from ECS. Probably your best option out there.
Old May 5, 2010 | 01:44 PM
excessive81's Avatar
excessive81
innovator west
Old May 5, 2010 | 01:51 PM
DEODELTA's Avatar
DEODELTA
Thanks guys. ..looks like that's the one..next question. ....should I just stay at 7 3/4 or go 8. Will that be too much boost for a stock ls2 at 7.5lbs of boost and's at 527rwhp with that Maggie?
Old May 5, 2010 | 03:38 PM
Bad News's Avatar
Bad News
In my opinion the 8" with a good tune will be just fine. Im going to be pushing 9-10lbs on my stock ls2 and my tuner said it would not be a problem.
To crank pulley
