C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Blower Spec Cams
Old May 20, 2010 | 05:44 PM
LoneStarFlyer's Avatar
LoneStarFlyer
Default Blower Spec Cams
I'm contemplating a roots or centri style blower and am wondering if my existing aftermarket cam is suitable for FI. I see references to blower spec cams but am uncertain what cam attributes are desirable in a FI setup, although I suspect it in part deals with maintaining sensible cylinder pressures given the added boost. My current cam is a 228/232@.050, .590/.598 lift with a 113 CL. Engine has stock compression and heads with LG long tubes. Any advice will be appreciated!
Old May 20, 2010 | 07:05 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
if your crank is already pinned, then i would just leave that cam in there.
but if you have to tear it all out to pin it, then you mine as well swap it out.
-carl
