Nitrous Help
I got it home and got looking around. I'm noticing that two of the NOS spray nozzles were loose where they are installed into the manifold..one much more than the other (easily pull/wiggle it out of the manifold by hand and no effort, also hear air whistle around the nozzle w/ motor running) . With the engine running I am able to determine that air is being sucked in/out at the nozzle/manifold area, more so at the one mentioned. Assuming this is the problem? What would be the best option to seal these to eliminate the air by-pass. I'm assuming the extra airflow is what was keeping the RPMs from dropping back to normal at stop. Any thoughts.
I've checked all the other nozzles and they seem to be tight. The car is a 06 Z with w/ 16K miles. Would a good sealant around the nozzle bases be a cure and if so any particular sealant suggested? The NOS was on the car when I bought it and the prior owner claims she only sprayed once or twice over the last few years. The car is 700 HP without the spray. I have yet to spray it and now I'm leary if I ever decide to spray..just want to make sure all is sealed well. I'm hoping this is the only issue. Thanks for any input.
Did some trial and error. Found some good sealant. Put some around the nozzles sealed the area..Problem solved. Running great..Lesson learned every day.
The car is idleing like that because the loose nozzle may be causing a vacumme leak letting in un measured air. This would also cause a lean condition so you need to fix it before driving it.
If you need any advice let me know.
Dave
