C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
2009 LS3 Supercharged.
Old Jun 23, 2010 | 06:53 PM
C6BIX's Avatar
C6BIX
Default 2009 LS3 Supercharged.
Guys its 102 out side and in trafic or sitting still for 10 min the car get to 230. Will go back down to 195ish when running on highway. Is that normal?
Old Jun 23, 2010 | 07:18 PM
adam205348's Avatar
adam205348
Well unfortunately it is one of those things with a intercooler in front of the radiator. Do you have a stock radiator? Do you know if your tuner set the fans to come on lower in the temp range?
Old Jun 23, 2010 | 07:25 PM
C6BIX's Avatar
C6BIX
Default Stock Rad.
I am not sure what temp the tuner set the fans to come on...
Old Jun 23, 2010 | 07:27 PM
Robls6's Avatar
Robls6
Do yourself a favor and get a Dewitts (or other) aluminum radiator. The stock one is not big enough to handle the extra load put on it.
Old Jun 23, 2010 | 07:34 PM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
True dat !
Old Jun 23, 2010 | 07:49 PM
vettemann62's Avatar
vettemann62
I had the same situation but realized I had some some leaves stuck between my radiator & ac condenser. I cleaned out the leaves & went with a "water-wetter" solution & my temps came back down. Don't overlook the obvious before spending more dough $$$$. Make sure your fans on at their highest speed by 200 degrees.
Old Jun 23, 2010 | 07:58 PM
Robls6's Avatar
Robls6
Turning the fans on high speed is not the best way to handle the heat problem. First off the car sounds terrible with the fans on full speed all the time, second... the fans running like that all the time has a tendency to actually overheat the wiring harness to them causing more problems. My 07 A&A car with a dewitt's rad (no oil or trans coolers) keeps the car at 195-198 with a stock thermostat and the fans hardly ever run (unless sitting for a while in traffic). If you spent $8000 for a blower kit wouldn't another $600 or so for a good radiator be a good idea?
Old Jun 23, 2010 | 09:40 PM
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
230* is typical in traffic If you start seeing 245-250*, you may want to look into an electric water pump, which will drop the lower the stop and go by 10-15*, but it sounds like your temps are under control.
Old Jun 23, 2010 | 09:56 PM
filmjay's Avatar
filmjay
St. Jude Donor '10
I've topped 250 once on a long I-state drive with the A/C on full blast. Average is about 230-235 in sloooow traffic with the A/C on...and a true 100* outside.
Road course guys see 260-280's under track conditions....so 230 isn't gonna kill your motor. It's "okay", but not great. Anything you can do to lower temps is only going to help though.
I was going to go the meth route. But after this heatwave, a EOC/TOC radiator has taken the top spot on my "Corvette to-do" list.
Old Jun 23, 2010 | 10:15 PM
Robls6's Avatar
Robls6
No way road course cars hit 280 degrees. Even with a pressurized system the coolant would boil over.
Old Jun 23, 2010 | 10:24 PM
NJLS708's Avatar
NJLS708
Anything over 250 is getting into dangerous territory. Actually doesnt the coolant gauge show 260 to be in the red?? Meaning overheating!
Old Jun 23, 2010 | 10:33 PM
Slvr08Z51's Avatar
Slvr08Z51
before you go buying a radiator, i would run distilled water and some red line watter wetter in the summer. I dropped my coolant temps 10-12 last summer doing this. I will first put dual fans on it before the dewitts, I believe it's not the radiator that is the weak link, I believe it's airflow.
Old Jun 23, 2010 | 10:48 PM
Taylor@DallasPerformance's Avatar
0Taylor@DallasPerformance
Former Vendor
Incorrect. Ethylene glycol has a boiling point of almost 200C (390F). When used in a 50/50 mix with water it has a boiling point of around 250 degrees F. Propylene glycol is a little lower around 190C. Add in 14# pressure in the mix and you just raised the boiling point 40F. So yes you can absolutely run a road race car that hot and many people do.
Former Vendor
Who told you that?!? LOL
Old Jun 23, 2010 | 11:02 PM
Slvr08Z51's Avatar
Slvr08Z51
A very wise man!
Old Jun 24, 2010 | 08:54 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I have spent entire sessions on the road course at Bondurant with temps over 250 the whole time, the car looses a lot of power, but drives fine. (but I wouldn't do it with my own car!!)
Old Jun 24, 2010 | 12:45 PM
glad2hver's Avatar
glad2hver
My car regularly gets to ~ 230. In fact, some WOT blasts in the heat with A/C got me 249.
I did check the hardware up front and, my God, it's cramped and looks poorly designed, particularly with that relatively narrow body opening. And now with cooler stacked one in front of the other.
Glad to finally get confirmation that > 230 is getting high, certainly 249.
I already have RedLine water wetter on order
To 2009 LS3 Supercharged.
Old Jun 24, 2010 | 03:35 PM
glad2hver's Avatar
glad2hver
ooops!
I quote oil temp. coolant well below that, ~ <= 205deg
my bad :o
Old Jun 24, 2010 | 07:15 PM
EuroRod's Avatar
EuroRod
My setup: 2005, mn6, LS2.
Meziere electric water pump (55 gph constant flow)
160 degree t'stat
Ron Davis radiator with oil cooler
Intercooled ProCharger
AR Headers
Big Bollas mod on intercooler location
Two days ago I saw 105 degrees on the OS air temp. At 80 mph with 60 degrees dialed into the ac, I saw 194 coolant temp and 208 oil temp. In traffic, the fluid temps actually fall about 10 degrees.
With reasonable OS air temps, ie less than 90 degrees, I normally see coolant temps in the low 180 range and oil temp about 10 degrees higher.
My tuner says it's the coolest running C6 he's ever seen.
Old Jun 25, 2010 | 01:54 PM
glad2hver's Avatar
glad2hver
160 degree t'stat
AR Headers
Wow....that's low!
Driving at night at ~ 80deg, my oil temp hit 214 and coolant ~ 185. I just added Water Wetter additive to coolant via overflow. I'll give it a few days to mix and hopw to see some improvement
