C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
fuel system help
Old Jun 28, 2010 | 09:30 PM
C6 Twin Turbo's Avatar
C6 Twin Turbo
Default fuel system help
Hey guys i am looking for some advice, My car sputtered and stoped running the other day. My fuel pump went out on me two years ago, the msd b.a.p. voltage went up and burned up the pump. I had them put a z06 pump back in the car. I tracked the car Friday at a road course, drove the hour back home and parked the car. I went out and moved it, then went to move again and it started then quit running. I added fuel to the car and heard a pump (jet syphone) maybe run. I founf that the car had over 1/2 a tank of gas. Did not start again. I checked the MSD fuse and it was good. I checked the 20 amp fuel pump fuse and swithed the relay to check. The car still will not start. No pressure in the fuel rail.
my tuner put an extra nut on the BAP last time to make sure it could not come loose again.
Do you have any other suggestions?
Thanks for your help.
Kevin
