Those with h/c z06 with a 100 shot, what are your hp/torque numbers?
What's your setup (progressive, 1st gear lockout) etc, and how much timing have you pulled in your tune? I live in Houston where it's hot and I want to be safe!
Z06 bolt ons and camshaft. I installed a single 75 shot TNT nozzle and got alittle more that 100 to the wheels. No timing pulled. Simple install with no controller. No issues.
i spray mine out of the hole, no timing pulled for 100 shot just use race gas when spraying, the hotter it is outside the safer you are
