Spark plugs
St. Jude Donor '10
Going procharger soon. Looking to make around 6-8psi. Do I also need to order a set of sparks? I think I saw the A&A kit come with some colder ones?
I would. Get recommendations from Dallas Performance, A&A, or ECS.
If it were me (and I am not an expert), I would start colder and go warmer once proven. Something like a BR7EF is two heat ranges colder, and non-projected-tip. A more common plug for your application would be a TR6, which is one heat range colder than stock, and projected-tip. But again, get expert advice.
Depends on if you have a Z06 or a C6. TR6 is stock heat range on a Z06. For 9psi or less, one step colder will be good.
Make sure your AFR is fat and your tuner understands the timing multipliers or you'll be picking up the pieces.
