There are much better fuel systems available. I would get a Dallas Performance fuel systems if you are looking for a proven, yet complete 1,000+ hp fuel system.
Another vote for the www.dallasperformance.com fuel system with the 190lb per hour injectors, I have had their 1800hp fuel system in my car for 2+ years now, the very best money can buy, I just upgraded to the new 190lb injectors... E85 here we come!!!
Another great option is Aeromotives In Tank Pro Series Fuel Pump that supports 1700hp in a forced induction application and doesn't require you to drill holes into your fuel tanks. I have a complete system that I can package together for you. It would include:
Pro Series In Tank Fuel Pump
Fuel Pump Feed and Return Fittings
Fuel Filter
Filter Bracket
Fuel Pump Speed Controller (keeps the pump quiet and prevents overheating)
Fuel Pressure Regulator
Fuel Rails
Y-Block
Complete pre-assembled fuel line kit
Everything you need to convert your fuel system is included. If you'd like more information and pricing, shoot me an email. jeremy@houseofboost.com
Fuel Filter
Filter Bracket
Fuel Rails
Y-Block
Jeremy, can you post up some pics on the pump etc...
the reason im asking for this fuel system is because i already have one in another car i just want to copy and paste to my second car
does Dallas Performance have one with 100lb injectors? without any impedance converters?
also, I dont know if you need 100lbs injectors, BUT I know Jim@speedinc tuned a few more APS turbo Z06s with 85lbs high impedance injectors and they worked perfectly.
I did get the 80 pounders from Jim, but for some reason the car never wanted to idle properly, and as soon as I swapped the injectors out, it idled properly. its worth mentioning I tried alot of things in the tune, but it just didnt want to work.
Here are a few pics of the fuel pump assembly. It replaces the driver side tank assembly. I also carry large high impedance injectors (80lb, 85lb, 1000cc, 2000cc) so everything you need for your fuel system can be purchased in one place.
