I went with the HSW microedge. But no real reason as to why I went with it other than its the first one I found and seams to do what I needed it to do. sorry no real help. I haven't installed it yet need to upgrade the fuel system to make the NO2 work though since I already have a cam. I'll be over 600hp with the nitrous. so everything is sitting in a box waiting to put on.
I found some input on another forum that made it sound like a pretty solid unit.
I assume the factory o2 sensors are narrow band right? It mentions you can run the a/f shut down switch off a narrow band sensor... do many people do this?
I'd like to have that extra level of protection on top of the WOT and RPM window switches, but I would prefer to not buy a whole wideband setup to install in the car.
yes the factory ones are narrow band PM spinmonster that guy knows his Nirtous and the corvette. as far as tapping into the stock o2 sensor. I know they aren't as good as the wideband but are they good enough I would like to say yes. but that is just a guess.
im doing same thing and i went ahead and orderd the hsw controller and have been waiting for a month now they say it should be in stock by end of sept.
