Does anyone have Stock cube Ls3 TT VS Blower dynos? im trying to compater the 2 setups at Equal power levels. IE 700rwhp TT car vs 700 rwhp Centrifugal blower car.
although what I would be more interested in is dyno comparisons of like for like motors, one running x PSI from a blower and the other running the same boost via turbo. I'm guessing if the blower made ~700 the turbo would make ~10% more.
Im not really interested in peak.. just want to see mid range and power band.
TURBO FTW. Take that to the bank. I've had several of both. Turbo car is definatly faster, and more fun to drive. The centri will hook up and put the power down smoother, but thats it.
IMO, Centri cars are borring to drive. Mine made over 900 to the tires, and my turbo car making much less is a blast to drive. If I was going to have a SC car I would rather have a Big Roots style blower instead of a Centri.
He wants DYNO SHEETS, not how you think one feels faster and the other is boring... read the OP again.
thanks in advance.
The TT car is going to make the power on less boost and make it earlier unless it uses some huge turbos. It will take less fuel to do it as well.
I think most already know the pros/cons of turbo vs centri. I am guessing OP wants to see the power drop off between shifts at certain rpm ranges. He is a stickler for the power under the curve analysis.
Most of us just downshift when the other guys has more power under the curve.
What size turbo would compare be a fair comparison to a X blower???? Does it matter if there is one or two turbos?
I wonder if thats going to affect the wanted "DYNO SHEET"?
Take it easy buddy, your opinion was noted in the everlasting turbo v centri v roots argument.
I'm fine. I'm not one to argue on the internet. All power adders are going to make power. Its just real hard to out run a turbo car.
I posted my .02 now I'm out.
